5.05510.3601303
5.05510.3601303
    RAFI
    LENS RED SQUARE FOR 8.1MM PB
5.05510.3601303 数据手册
8 mm Series 1 8 mm General data Illuminable pushbuttons and signal lamps with lamp socket for a mounting hole diameter of 8.1 mm; 42 V, 250 mA max. Please order lamps/LEDs separately. Content 8 mm Series, illuminated pushbutton, 42 V/250 mA 8 mm Series, illuminated pushbutton, round collar, 42 V/250 mA 8 mm Series, illuminated pushbutton, square collar, 42 V/250 mA 1-4 1-5 1-5 8 mm Series, signal lamp 8 mm Series, signal lamp, round collar 8 mm Series, signal lamp, square collar 1-6 1-7 1-7 Pushbuttons Stock items are marked by bold printed order numbers. 1-3 8 mm Series 8 mm Series, illuminated pushbutton, 42 V/250 mA 1 8 mm Mounting hole Technical data General information Form of lens Colour of lens Form of collar protruding lens see order block see order block Dimensions Length of collar Diameter of collar Width of collar Overall height Mounting depth Mounting hole see order block see order block see order block 9 mm 31 mm 8.1 mm Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illuminability Lamp socket Mechanical characteristics Operating force max. Operating travel Switching travel NO Robustness Electrical characteristics Rated voltage AC/DC max. Rated voltage AC/DC min. Rated current AC/DC max. Rated current AC/DC min. Contact resistance max. Bouncing time max. Other specifications Operating life (operations) ring nut solder terminals, tin-plated 2 plate springs see order block 1 NO Au yes Bi-Pin T 1 2.6 N 2.7 mm 1 mm 100 N Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. without lamp /LED Ambient temp. operating max. with lamp /LED Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment Weight Soldering time max. Soldering temperature max. 42 V 0.02 V 250 mA 0.01 mA 100 mΩ 10 ms 1000000 (momentary), 100000 (latching) IP40 -25 °C +70 °C +55 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 2g 3 sec. 350 °C Accessories 8 mm Series, illuminated pushbutton, 42 V/250 mA Description Photo Order no. Page Filament lamp, Bi-Pin T 1 base, 24 - 28 V 1.90.180.473/0000 5 - 5 LED Bi-Pin T 1, red, 3 V 1.90.691.026/0000 5 - 17 LED Bi-Pin T 1, green, 3 V 1.90.691.027/0000 5 - 17 1-4 Stock items are marked by bold printed order numbers. Pushbuttons 8 mm Series Accessories 8 mm Series, illuminated pushbutton, 42 V/250 mA Description Photo Order no. Page LED Bi-Pin T 1, yellow, 3 V 1.90.691.028/0000 5 - 17 Fixing spanner M 8 5.58.002.027/7705 5 - 25 1 8 mm 8 mm Series, illuminated pushbutton, round collar, 42 V/250 mA Pict.: with colourless lens Mounting hole Contact arrangement Contact function Lamp socket Order no. without lens 1.15.116.001/0000 Please include the desired lens in your order. 1.15.116.011/0000 Please include the desired lens in your order. 1 NO momentary Bi-Pin T 1 1 NO latching Bi-Pin T 1 Note Technical data see page 1 - 4 Lens, transparent colourless: 5.05.510.470/1002 Lens, transparent red: 5.05.510.470/1303 Lens, transparent yellow: 5.05.510.470/1402 Lens, transparent green: 5.05.510.470/1502 8 mm Series, illuminated pushbutton, square collar, 42 V/250 mA Pict.: with green lens Mounting hole Contact arrangement Contact function Lamp socket Order no. without lens 1.15.116.021/0000 Please include the desired lens in your order. 1.15.116.031/0000 Please include the desired lens in your order. 1 NO momentary Bi-Pin T 1 1 NO latching Bi-Pin T 1 Note Technical data see page 1 - 4 Lens, transparent colourless: 5.05.510.471/1002 Lens, transparent red: 5.05.510.471/1303 Lens, transparent yellow: 5.05.510.471/1402 Lens, transparent green: 5.05.510.471/1502 Pushbuttons Stock items are marked by bold printed order numbers. 1-5 8 mm Series 8 mm Series, signal lamp 1 8 mm Mounting hole Technical data General information Form of lens Colour of lens Form of collar protruding lens see order block see order block Dimensions Length of collar Width of collar Diameter of collar Overall height Mounting depth Mounting hole 8.9 mm 8.9 mm see order block 9 mm 31 mm 8.1 mm Mechanical design Mounting Terminals Other specifications Degree of protection from front side Weight Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Lamp socket Lamp ring nut solder terminals, tin-plated Bi-Pin T 1 filament lamp / LED Electrical characteristics Voltage limit max. Power limit max. 24 V 0.4 W Resistance at variable environment Soldering time max. Soldering temperature max. IP40 2 -25 °C +55 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 3 sec. 350 °C Accessories 8 mm Series, signal lamp Description Photo Order no. Page Filament lamp, Bi-Pin T 1 base, 24 - 28 V 1.90.180.473/0000 5 - 5 LED Bi-Pin T 1, red, 3 V 1.90.691.026/0000 5 - 17 LED Bi-Pin T 1, green, 3 V 1.90.691.027/0000 5 - 17 LED Bi-Pin T 1, yellow, 3 V 1.90.691.028/0000 5 - 17 Fixing spanner M 8 5.58.002.027/7705 5 - 25 1-6 Stock items are marked by bold printed order numbers. Pushbuttons 8 mm Series 8 mm Series, signal lamp, round collar 1 Pict.: with colourless lens Voltage limit max. 24 V Mounting hole Power limit max. Lamp socket 0,4 W Bi-Pin T 1 Colour of lens Order no. without lens Note 8 mm 1.65.120.001/0000 Please include the desired lens in your order. Technical data see page 1 - 6 Lens, transparent colourless: 5.05.510.359/1002 Lens, transparent red: 5.05.510.359/1303 Lens, transparent yellow: 5.05.510.359/1402 Lens, transparent green: 5.05.510.359/1502 8 mm Series, signal lamp, square collar Pict.: with green lens Voltage limit max. 24 V Mounting hole Power limit max. Lamp socket 0,4 W Bi-Pin T 1 Colour of lens Order no. without lens Note 1.65.120.011/0000 Please include the desired lens in your order. Technical data see page 1 - 6 Lens, transparent colourless: 5.05.510.360/1002 Lens, transparent red: 5.05.510.360/1303 Lens, transparent yellow: 5.05.510.360/1402 Lens, transparent green: 5.05.510.360/1502 Pushbuttons Stock items are marked by bold printed order numbers. 1-7
5.05510.3601303 价格&库存
很抱歉,暂时无法提供与“5.05510.3601303”相匹配的价格&库存,您可以联系我们找货
