CNX_310_012_X_4_1_24
    VCC
CNX_310_012_X_4_1_24 数据手册
8 6 7 5 4 2 3 NOTES: 1. 2. D 3. 4. 5. 6. 7. 8. C ECN # ROHS COMPLIANT MATERIAL: PANEL CONNECTOR - POLYPROPYLENE, UL RATING 94-HB HEADER CONNECTOR - POLYESTER, UL RATING 94-V0 LENS - POLYCARBONATE - UL RATING 94-V2 MOISTURE SEAL - EPDM RING - THERMOPLASTIC TERMINALS - PHOSPHER BRONZE, TIN PLATE WIRE - 24 AWG 1007/1569 MOUNTING: HOLE SIZE.281" (7.2mm) OPENING ON 3/8" CENTERS (9.52mm) PANEL THICKNESS: .030" (0.76mm) MIN TO .125" (3.18mm) MAX FOR PANEL THICKNESS .030" (0.76mm) TO .045" (1.14mm) USE TWO (2) SPC 060 SPACERS FOR PANEL THICKNESS .050" (1.27mm) TO .100" (2.54mm) USE ONE (1) SPC 060 SPACER FOR PANEL THICKNESS .105" (2.67mm) TO .125" (3.18mm) NO SPACER REQUIRED LED LEAD LENGTH: FOR CMC 285 - .350" .010 (8.89mm 0.25) FOR CMC 313, CMC 321, CMC 323, AND CMS 322 - .220" .010 (5.59mm 0.25) FOR STANDARD DRY APPLICATIONS USE CMC 285, CMC 313, CMC 321 OR CMC 323; FOR WET OR DRY APPLICATIONS USE CMS 322 (MEETS NEMA4/ IP56) ALSO CAN BE ORDERED CNX 310 XXX FOR CONNECTOR AND RESISTOR ONLY U.S AND FOREIGN PATENT ISSUED REV 001 1 REVISIONS DESCRIPTION REVISED PER ECR 111009AZ01 INITIALS KH D 7 LENS (ORDER SEPERATELY) CABLE ORDERING CODE EXAMPLE: CNX 310 056 E 4 1 08 * CALL FACTORY FOR ADDITIONAL OPTIONS LED & SPACER (ORDER SEPERATELY) C CMC 285 000 = 012 = 018 = 033 = 056 = 120 = 220 = RESISTOR * NO RESISTOR 120 OHMS 180 OHMS 330 OHMS 560 OHMS 1200 OHMS 2200 OHMS TERMINATION * STRIPPED END SINGLE ROW LOCKING HEADER SINGLE ROW PLAIN HEADER X= E= G= 5MM LED WIRE SIZE * 4= 24 AWG WIRE COLOR * 1 = WHITE - BLACK 2= RED - BLACK 04 = 06 = 08 = 12 = 18 = 24 = WIRE LENGTH * 4 INCHES (101.6mm) 6 INCHES (152.4mm) 8 INCHES (203.2mm) 12 INCHES (304.8mm) 18 INCHES (457.2mm) 24 INCHES (609.6mm) CMC 313 CMC 321 CMC 323 PIN B = ANODE (+) WHITE LEAD B B W1 1 2 W2 CMS 322 PIN A = CATHODE (-) BLACK LEAD SPC 060 .480 12.19mm XX.XX DIMENSION STYLE: INCHES / MM GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED: INCHES MM A MATERIAL OPTOELECTRONICS SEE NOTES .500 12.7 190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com FINISH TITLE: CNX 310 XXX CABLE ASSEMBLY SEE NOTES THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 8 DATE 2/22/11 7 6 5 4 3 DATE APPROVAL DRAWN CHECKED K.Howard AZ REV SIZE DWG. NO. 2/22/11 B 2/22/11 CNX 310 XXX ASSY SCALE: 2:1 DO NOT SCALE DRAWING 2 001 SHEET 1 OF 1 1 A
1. 物料型号:文档中提到了多个型号,例如CMC 285, CMC 313, CMC 321, CMC 323, 和 CMS 322。
2. 器件简介:文档描述了一种光电器件,包括其材料组成,如聚丙烯面板连接器、聚酯头连接器、聚碳酸酯镜头、EPDM密封圈和热塑性材料。
3. 引脚分配:文档中提到了LED的引脚分配,例如PIN A作为阴极(-),黑色引线;PIN B作为阳极(+),白色引线。
4. 参数特性:包括电阻值(如120欧姆、180欧姆、220欧姆、1200欧姆、2200欧姆、330欧姆、560欧姆)、电线规格(24 AWG)、电线长度选项等。
5. 功能详解:文档提供了详细的功能描述,如LED引线长度、面板厚度要求、安装孔尺寸、LED和电阻的订购代码示例。
6. 应用信息:文档提到了适用于标准干燥应用和潮湿或干燥环境的型号,以及NEMA4/IP56标准的符合性。
7. 封装信息:提供了封装的尺寸和公差信息,以及材料的一般公差。
CNX_310_012_X_4_1_24 价格&库存
很抱歉,暂时无法提供与“CNX_310_012_X_4_1_24”相匹配的价格&库存,您可以联系我们找货
    • 1+56.92680
    • 200+22.71240
    • 500+21.95640
    • 1000+21.57840
