CNX_410_018_X02_4_1_04 数据手册
8
5
6
7
4
2
3
1
REVISIONS
NOTES:
1.
2.
D
3.
4.
5.
6.
7.
8.
ROHS COMPLIANT
MATERIAL:
PANEL CONNECTOR - THERMOPLASTIC, WHITE, UL RATING 94-V0
HEADER CONNECTOR - POLYESTER, UL RATING 94-V0
LENS - POLYCARBONATE - UL RATING 94-V2
MOISTURE SEAL - EPDM
LOCK WASHER - STEEL, NICKEL PLATE
TERMINALS - PHOSPHER BRONZE, TIN PLATE
WIRE - 24 AWG 1007/1569
MOUNTING: HOLE SIZE .313" (7.9mm) OPENING ON 1/2" CENTERS (12.7mm)
PANEL THICKNESS: UP TO .125" (3.18mm) MAX
LED LEAD LENGTH: .250" +/- .01 (6.35mm +/- .254)
FOR STANDARD DRY APPLICATIONS USE CMC 441, FOR WET OR DRY
APPLICATIONS USE CMS 442 (MEETS NEMA 6P/ IP67)
LABEL TEXT: "CNX 410 XXX; XXX0 Ohms"
U.S AND FOREIGN PATENT ISSUED
REV.
DESCRIPTION
DATE
INITIALS
CHK'D
425
000
REVISED PER ECR 032112ED01
5/1/12
KH
ED
D
LENS W/ LOCKWASHER
(ORDER SEPARATELY)
CABLE ORDERING CODE EXAMPLE:
CNX 410 056 E02 4 1 08
C
ECN #
* CALL FACTORY FOR
ADDITIONAL OPTIONS
LED
(ORDER SEPARATELY)
C
CMC 441
012 =
018 =
033 =
056 =
120 =
220 =
RESISTOR *
120 OHMS
180 OHMS
330 OHMS
560 OHMS
1200 OHMS
2200 OHMS
TERMINATION *
STRIPPED END
SINGLE ROW LOCKING HEADER
X=
E=
WIRE SIZE *
4=
24 AWG
WIRE COLOR *
1 = WHITE - BLACK
2=
RED - BLACK
LABEL
04 =
06 =
08 =
12 =
18 =
24 =
WIRE LENGTH *
4 INCHES (101.6mm)
6 INCHES (152.4mm)
8 INCHES (203.2mm)
12 INCHES (304.8mm)
18 INCHES (457.2mm)
24 INCHES (609.6mm)
CMS 442
(MOISTURE
SEALED)
PIN B = ANODE (+) WHITE OR RED LEAD
5MM LED
B
B
W2
W1
PIN A = CATHODE (-) BLACK LEAD
.550in
13.97mm
XX.XX"
DIMENSION STYLE: INCHES / MM
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED:
INCHES
MM
A
.500
12.7
APPROVAL
DATE
DRAWN
KHOWARD
5/1/12
CHECKED
EDEGUZMAN
5/2/12
12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A
PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
CNX 410 CABLE
ASSEMBLY
SEE NOTES
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
8
7
6
5
4
3
REV
SIZE DWG. NO.
N/A
B
CNX 410 XXX ASSY
SCALE: 2:1
DO NOT SCALE DRAWING
2
000
SHEET 1 OF 1
1
A
CNX_410_018_X02_4_1_04 价格&库存
很抱歉,暂时无法提供与“CNX_410_018_X02_4_1_04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+57.587251+7.45309
- 10+48.9278410+6.33236
- 25+45.8620625+5.93558
- 50+43.6697050+5.65184
- 100+41.58578100+5.38214
- 300+38.48382300+4.98067
- 500+37.12230500+4.80446
- 1000+35.351991000+4.57534
- 2500+33.141532500+4.28926
