CNX_C_X_4_2_24
CNX_C_X_4_2_24
    VCC
    CNX_C_X_4_2_24
CNX_C_X_4_2_24 数据手册
8 7 5 6 4 2 3 NOTES: 1. 2. D 3. 4. 5. 6. ECN # ROHS COMPLIANT MATERIAL: PANEL CONNECTOR SOCKET - POLYPROPYLENE, UL RATING 94-HB HEADER CONNECTOR - POLYESTER, UL RATING 94-V0 TERMINALS - PHOSPHOR BRONZE, TIN PLATE WIRE - 24 AWG 1007/ 1569 MOUNTING: HOLE SIZE - 9/32" (7.14mm) PANEL THICKNESS: .030" ( .762mm) MIN - .125" (3.175mm) MAX FOR PANEL THICKNESS .030" (.762mm) - .045" (1.143mm) USE 2 SPC 060 SPACERS FOR PANEL THICKNESS .050" (1.27mm) - .100" (2.54mm) USE 1 SPC 060 SPACER FOR PANEL THICKNESS .105" (2.67mm) - .125" (3.175mm) NO SPACER REQUIRED LED LEAD LENGTH: FOR CMC 285 - .350" .01" (8.89mm 0.254mm) FOR CMC 313, CMC 321, CMC 323, AND CMS 322 - .250" 0.01" (6.35mm 0.254) U.S. & FOREIGN PATENT ISSUED AND PENDING 1 REVISIONS REV DESCRIPTION 001 REVISED PER ECR 111009AZ01 DATE 11/26/10 INITIALS KH LENS/ PANEL MOUNT (ORDER SEPARATELY) D LED/ SPACER (ORDER SEPARATELY) CABLE ORDERING CODE EXAMPLE: CMC 285 CNX C E 4 1 12 C C X= E= G= 5MM LED TERMINATION * STRIPPED END SINGLE ROW LOCKING HEADER SINGLE ROW PLAIN HEADER 4 WIRE SIZE * 24 AWG 1 2 WIRE COLOR * WHITE - BLACK RED - BLACK * CALL FACTORY FOR WIRE LENGTH * 04 06 08 12 18 24 4 INCHES (101.6mm) ADDITIONAL 6 INCHES (152.4mm) OPTIONS 8 INCHES (203.2mm) 12 INCHES (304.8mm) 18 INCHES (457.2mm) 24 INCHES (609.6mm) CMC 313 CMC 321 CMC 323 B B SPC 060 CMS 322 ANODE (+) WHITE OR RED LEAD 1 2 W2 W1 1 2 CATHODE (-) BLACK LEAD .690 17.526mm XX.XX DIMENSION STYLE: INCHES / MM GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED: INCHES MM A MATERIAL OPTOELECTRONICS SEE NOTES .500 12.7 190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com FINISH TITLE: CNX C CABLE ASSEMBLY SEE NOTES THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 8 7 6 5 4 3 APPROVAL DATE DRAWN K.Howard 11/26/10 CHECKED DPZ 11/26/10 REV SIZE DWG. NO. B SCALE: 1:1 DO NOT SCALE DRAWING 2 CNX C ASSY 001 SHEET 1 OF 1 1 A
CNX_C_X_4_2_24 价格&库存
很抱歉,暂时无法提供与“CNX_C_X_4_2_24”相匹配的价格&库存,您可以联系我们找货
