SIT5001AC-GE-33VB-40.000000T 数据手册
SiT5001
1-80 MHz MEMS TCXO and VCTCXO
The Smart Timing Choice
Features
Applications
Any frequency between 1 and 80 MHz accurate to 6 decimal places
WiFi, 3G, LTE, SDI, Ethernet, SONET, DSL
100% pin-to-pin drop-in replacement to quartz-based (VC)TCXO
Telecom, networking, smart meter, wireless, test instrumentation
Frequency stability as low as ±5 ppm. Contact SiTime for tighter
stability options
Ultra low phase jitter: 0.5 ps (12 kHz to 20 MHz)
Voltage control option with pull range from ±12.5 ppm to ±50 ppm
LVCMOS compatible output with SoftEdge™ option for EMI reduction
Voltage control, standby, output enable or no connect modes
Standard 4-pin packages: 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm
Outstanding silicon reliability of 2 FIT, 10 times better than quartz
Pb-free, RoHs and REACH compliant
Electrical Characteristics
Parameter
Output Frequency Range
Initial Tolerance
Symbol
Min.
Typ.
Max.
Unit
f
1
80
MHz
Condition
F_init
-1
1
ppm
At 25°C after two reflows
Stability Over Temperature
F_stab
-5
+5
ppm
Over operating temperature range at rated nominal power
supply voltage and load. (see ordering codes on page 6)
Supply Voltage
F_vdd
50
ppb
±10% Vdd (±5% for Vdd = 1.8V)
15 pF ±10% of load
Contact SiTime for tighter stability options.
Output Load
F_load
0.1
ppm
First year Aging
F_aging
-2.5
+2.5
ppm
25°C
-4.0
+4.0
ppm
25°C
10-year Aging
Operating Temperature Range
Supply Voltage
Pull Range
T_use
Vdd
-20
+70
°C
Extended Commercial
-40
+85
°C
Industrial
1.71
1.8
1.89
V
Contact SiTime for any other supply voltage options.
2.25
2.5
2.75
V
2.52
2.8
3.08
V
2.70
3.0
3.3
V
2.97
3.3
3.63
V
PR
±12.5, ±25, ±50
ppm
Upper Control Voltage
VC_U
Vdd-0.1
V
Control Voltage Range
VC_L
0.1
V
Control Voltage Input Impedance
Z_vc
100
k
Frequency Change Polarity
Control Voltage -3dB Bandwidth
Current Consumption
OE Disable Current
Standby Current
Duty Cycle
LVCMOS Rise/Fall Time
Positive slope
All Vdds. Voltage at which maximum deviation is guaranteed.
V_BW
8
kHz
Idd
31
33
mA
No load condition, f = 20 MHz, Vdd = 2.5V, 2.8V or 3.3V.
29
31
mA
No load condition, f = 20 MHz, Vdd = 1.8V.
31
mA
Vdd = 2.5V, 2.8V or 3.3V, OE = GND, output is Weakly Pulled Down
30
mA
Vdd = 1.8 V. OE = GND, output is Weakly Pulled Down
I_std
70
µA
Vdd = 2.5V, 2.8V or 3.3V, ST = GND, output is Weakly Pulled Down.
10
µA
Vdd = 1.8V. ST = GND, output is Weakly Pulled Down.
DC
45
55
All Vdds
Tr, Tf
1.5
2
ns
LVCMOS option. Default rise/fall time, All Vdds, 10% - 90% Vdd.
I_OD
SoftEdge™ Rise/Fall Time
SoftEdge™ Rise/Fall Time Table
ns
SoftEdge™ option. Frequency and supply voltage dependent.
Output Voltage High
VOH
90%
Vdd
Output Voltage Low
VOL
10%
Vdd
Input Voltage High
VIH
70%
Vdd
Pin 1, OE or ST
Input Voltage Low
VIL
30%
Vdd
Pin 1, OE or ST
Input Pull-up Impedance
Z_in
100
250
k
SiTime Corporation
Rev. 1.0
990 Almanor Avenue
Sunnyvale, CA 94085
OH = -7 mA, IOL = 7 mA, (Vdd = 3.3V, 3.0V)
IOH = -4 mA, IOL = 4 mA, (Vdd = 2.8V, 2.5V)
IOH = -2 mA, IOL = 2 mA, (Vdd = 1.8V)
(408) 328-4400
www.sitime.com
Revised November 12, 2015
SiT5001
Electrical Characteristics (continued)
Parameter
Startup Time
OE Enable/Disable Time
Resume Time
Symbol
Min.
Typ.
Max.
Unit
Condition
T_start
10
ms
Measured from the time Vdd reaches its rated minimum value
T_oe
150
ns
f = 80 MHz. For other frequencies, T_oe = 100 ns + 3 cycles
T_resume
6
10
ms
Measured from the time ST pin crosses 50% threshold
T_jitt
1.7
2
ps
f = 10 MHz, Vdd = 2.5V, 2.8V or 3.3V
1.7
2
ps
f = 10 MHz, Vdd = 1.8V
0.5
1
ps
f = 10 MHz, Integration bandwidth = 12 kHz to 20 MHz, All Vdds
RMS Period Jitter
RMS Phase Jitter (random)
T_phj
Note:
1. All electrical specifications in the above table are measured with 15pF output load, Contact SiTime for higher drive options.
Pin Configuration
Pin
Symbol
Functionality
V control
1
[2]
Output
Enable
H or Open : specified frequency output
L: output is high impedance. Only output driver is disabled.
Standby
H or Open[2]: specified frequency output
L: output is low (weak pull down). Device goes to sleep mode. Supply
current reduces to I_std.
VC/OE/ST/NC
NC
2
Top View
Voltage control
VC/OE/ST
1
4
VDD
GND
2
3
OUT
No connect (input receiver off)
GND
Power
Electrical and case ground
3
CLK
Output
Oscillator output
4
VDD
Power
Power supply voltage
Note:
2. A pull-up resistor of
