8
5
6
7
4
2
3
1
NOTES:
1.
2.
D
3.
4.
5.
6.
7.
REVISIONS
ROHS COMPLIANT
MATERIAL:
PANEL CONNECTOR SOCKET - POLYESTER, UL RATING 94-V0
HEADER CONNECTOR - POLYESTER, UL RATING 94-V0
LENS - POLYCARBONATE, UL RATING 94-V2
MOISTURE SEAL - EPDM
LOCKWASHER - STEEL, NICKEL PLATE
TERMINALS - PHOSPHOR BRONZE, TIN PLATE
WIRE - 24 AWG 1007/ 1569
MOUNTING: HOLE SIZE - 9/16" (14.288mm) OPENING ON 3/4" (19.05mm) CENTER
PANEL THICKNESS: .030" ( .762mm) MIN - .188" (4.775mm) MAX
LED LEAD LENGTH:
FOR BI-LEAD - TRIM TO .300" 0.010 (7.620mm 0.254)
FOR HI-FLUX - NO TRIM REQUIRED
FOR TRI-LEAD - CONTACT FACTORY
FOR DRY APPLICATIONS USE HMC 461 OR HMC 463 LENS ; FOR DUST AND WET CONDITIONS
USE HMS 462 OR HMS 464 LENS ( EXCEEDS NEMA 6P/ IP 67)
U.S. & FOREIGN PATENT ISSUED
ECN #
431
REV.
DESCRIPTION
DATE
INITIALS
CHK'D
001
REVISED PER ECR 111009AZ01
11/26/10
KH
DPZ
001
REVISED PER ECR 050112KH01
5/9/12
KH
ED
D
LENS
(ORDER SEPARATELY)
CABLE ORDERING CODE EXAMPLE:
CNX 460 E02 4 1 12
LEDS
(ORDER SEPARATELY)
C
10MM BI-LEAD
X=
E=
D=
02 =
03 =
04 =
TERMINATION *
STRIPPED ENDS
SINGLE ROW LOCKING HEADER
DUAL ROW LOCKING HEADER
2 WIRES
3 WIRES
4 WIRES
4
WIRE SIZE *
24 AWG
1
2
6
WIRE COLOR *
WHITE - BLACK
RED - BLACK
WHITE - BLACK - RED
WHITE - BLACK - RED - GREEN
04
06
08
12
18
24
WIRE LENGTH *
4 INCHES (101.6mm)
6 INCHES (152.4mm)
8 INCHES (203.2mm)
12 INCHES (304.8mm)
18 INCHES (457.2mm)
24 INCHES (609.6mm)
C
* CALL FACTORY
FOR ADDITIONAL
OPTIONS
HMC 461
HMC 463
HMS 462
HMS 464
B
B
PIN B = CATHODE (-) BLACK LEAD
10MM TRI-LEAD
W2
W1
1
2
PIN A = ANODE (+) WHITE OR RED LEAD
1.023
25.994mm
XX.XX
DIMENSION STYLE: INCHES / MM
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED:
INCHES
MM
A
.500
12.7
APPROVAL
DATE
DRAWN
KHOWARD
11/26/10
CHECKED
DPZ
11/29/10
12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A
PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
CNX 460 CABLE
ASSEMBLY
SEE NOTES
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
8
7
6
5
4
3
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 1.75:1
DO NOT SCALE DRAWING
2
001
CNX 460 ASSY
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“CNX_460_X02_4_1_04”相匹配的价格&库存,您可以联系我们找货
