CNX_460_X02_4_1_18
CNX_460_X02_4_1_18
    VCC
    10MMTHREADEDCABLEASSY
CNX_460_X02_4_1_18 数据手册
8 5 6 7 4 2 3 1 NOTES: 1. 2. D 3. 4. 5. 6. 7. REVISIONS ROHS COMPLIANT MATERIAL: PANEL CONNECTOR SOCKET - POLYESTER, UL RATING 94-V0 HEADER CONNECTOR - POLYESTER, UL RATING 94-V0 LENS - POLYCARBONATE, UL RATING 94-V2 MOISTURE SEAL - EPDM LOCKWASHER - STEEL, NICKEL PLATE TERMINALS - PHOSPHOR BRONZE, TIN PLATE WIRE - 24 AWG 1007/ 1569 MOUNTING: HOLE SIZE - 9/16" (14.288mm) OPENING ON 3/4" (19.05mm) CENTER PANEL THICKNESS: .030" ( .762mm) MIN - .188" (4.775mm) MAX LED LEAD LENGTH: FOR BI-LEAD - TRIM TO .300" 0.010 (7.620mm 0.254) FOR HI-FLUX - NO TRIM REQUIRED FOR TRI-LEAD - CONTACT FACTORY FOR DRY APPLICATIONS USE HMC 461 OR HMC 463 LENS ; FOR DUST AND WET CONDITIONS USE HMS 462 OR HMS 464 LENS ( EXCEEDS NEMA 6P/ IP 67) U.S. & FOREIGN PATENT ISSUED ECN # 431 REV. DESCRIPTION DATE INITIALS CHK'D 001 REVISED PER ECR 111009AZ01 11/26/10 KH DPZ 001 REVISED PER ECR 050112KH01 5/9/12 KH ED D LENS (ORDER SEPARATELY) CABLE ORDERING CODE EXAMPLE: CNX 460 E02 4 1 12 LEDS (ORDER SEPARATELY) C 10MM BI-LEAD X= E= D= 02 = 03 = 04 = TERMINATION * STRIPPED ENDS SINGLE ROW LOCKING HEADER DUAL ROW LOCKING HEADER 2 WIRES 3 WIRES 4 WIRES 4 WIRE SIZE * 24 AWG 1 2 6 0 WIRE COLOR * WHITE - BLACK RED - BLACK WHITE - BLACK - RED WHITE - BLACK - RED - GREEN 04 06 08 12 18 24 WIRE LENGTH * 4 INCHES (101.6mm) 6 INCHES (152.4mm) 8 INCHES (203.2mm) 12 INCHES (304.8mm) 18 INCHES (457.2mm) 24 INCHES (609.6mm) C * CALL FACTORY FOR ADDITIONAL OPTIONS HMC 461 HMC 463 HMS 462 HMS 464 B B PIN B = CATHODE (-) BLACK LEAD 10MM TRI-LEAD W2 W1 1 2 PIN A = ANODE (+) WHITE OR RED LEAD 1.023 25.994mm XX.XX DIMENSION STYLE: INCHES / MM GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED: INCHES MM A .500 12.7 APPROVAL DATE DRAWN KHOWARD 11/26/10 CHECKED DPZ 11/29/10 12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com TITLE: MATERIAL CNX 460 CABLE ASSEMBLY SEE NOTES THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL FINISH THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 8 7 6 5 4 3 REV SIZE DWG. NO. SEE NOTES B SCALE: 1.75:1 DO NOT SCALE DRAWING 2 001 CNX 460 ASSY SHEET 1 OF 1 1 A
CNX_460_X02_4_1_18 价格&库存
很抱歉,暂时无法提供与“CNX_460_X02_4_1_18”相匹配的价格&库存,您可以联系我们找货
