910401X
910401X
    VCC
    LAMPHOLDER SLDR LUG BLACK
910401X 数据手册
910/911 Series Lampholders for 900/901 Cartridge Lamps Overview The 910 Series relampable lampholders accept any 900 Series cartridge lamp. These lampholders are of ruggedized contruction and are supplied with mounting hardware. Approvals UL Recognized. Specificiations Housing and Kunurled Ring Nut: Aluminum. Black anodized finish standard. Clear anodized finish optional. Other finishes available on special request. A mounting wrench, #097013, is available for tightening the knurled ring nuts. Hex Nut: Brass; nickel finish. Internal Tooth Lockwasher: Nickel-plated finish. Terminal Insulator: High dielectric composition. Terminals: Solder cup, turret pin or solder lug. Socket: Brass. Bright nickel-plated. Lens Cap: Heat resistant, high strength polycarbonate. Lens Marking: Lens style 21 maybe be stamped. Contact factory. 910 Series Maximum Rating: 3 Watts, 125 Volts. engineered to light up your design www.vcclite.com 1.800.522.5546 1
910401X 价格&库存
很抱歉,暂时无法提供与“910401X”相匹配的价格&库存,您可以联系我们找货
