426091300-3
426091300-3
    DIGITALVIEW
    CABLE RS232 EXT 100MM SERIES 2
426091300-3 数据手册
SGX-1920L High Resolution LCD Controller Board Key Features : > 10-bit, 1920 x 1200 > Dual Digital Picture In Picture > RS-232. Ethernet Control > Low Profile The SGX-1920L is a fully buffered multi-sync controller which provides 2x ARGB, 4x Composite and 2x HDMI input support for a wide range of TFT LCD panels up to WUXGA resolution. A true 10-bit board that gives 10-bit color depth on a 10-bit panel. The board features full screen image expansion, on screen PIP, image marker and supports an option 3G HD-SDI converter board (HD-3000) through the HDMI port for professional and broadcast video applications. Panel Connectivity 1920 x 1200 1920 x 1080 1680 x 1050 1600 x 1200 1440 x 900 1366 x 768 1280 x 1024 1280 x 768 Features 1024 x 768 800 x 600 800 x 480 640 x 480 Colors: Up to 10 bit per color, ie 1.06 Billion colors. Functions : On Screen Display (OSD) menu. Function Controls: External buttons, Infra-Red controls, Serial Port control, Ethernet Control Input Analog RGB: 60Hz at WUXGA, UXGA 75Hz at SXGA, WXGA, XGA, SVGA, VGA With auto detect of Digital Separate Sync, Sync-On-Green & Composite Sync. Auto detects VGA-WUXGA, interlaced & non-interlaced HDMI x2: 60Hz at WUXGA 75Hz at SXGA, WXGA, XGA, SVGA, VGA 1080p, 1080i, 720p, 576p, 480p Composite x4: NTSC /PAL/SECAM (Interlaced) Composite Video, S-video SD Component (YCbCr) HD Component (YPbPr) Reliability Calculated Mean Time Between Failures In excess of 100,000 hours. Warranty: 3 years. Image Scaling : Up / Down scaling to fit input to panel format. Image Control : Auto configuration, Brightness, Contrast, Clock, Phase, Color temperature, Image position, Saturation, Hue, Gamma. Other Features : System Information, OSD position, Scaling to fill screen and fill to aspect ratio, OSD timeout, Factory reset, OSD menu transparency, Picture in Picture - variable position with 18 sizes selection and Picture by Picture, Programmable hot keys, Ambient light sensor. Power : +12VDC ±5%,10W Panel Power : Supports 3.3V, 5V, 12V & 18V panels. Panel Signal : Dual channel LVDS support. Inverter Support : DPMS Enable pin (3.3V or 5V) Plug & Play : DDC 1,2/b compatible Status Indicator : Dual Color LED support. © Digital View Group Ltd 2011 | www.digitalview.com SGX-1920L High Resolution LCD Controller Board Connection Diagram INVERTER CNC3 LCD PANEL INVERTER CABLE CNC2 CNA2 CNB1 CNA1 PP1 POWER BOARD PR-1200 / PR-2400 PP2 PP3 PANEL SIGNAL & POWER FOR LVDS PANEL EXTERNAL PANEL POWER OUTPUT MAIN POWER INPUT IR RECEIVER CONNECTION PANEL POWER INPUT OPTIONAL LED J2 CONTROLLER (+5VDC) POWER IN & BACKLIGHT CONTROL IR1 J3 PP7 LED1 CN11 CN8 SW4 CNC1 SEL UP CONTROL CABLE SEL DN OSD FUNCTION - SW3 MENU CP2 ON/OFF CN1 CN10 + - RS-232 CONTROL INTERFACE CP1 SGX-1920L HDMI AUDIO (STEREO) OUTPUT SECONDARY RS-232 CONTROL INTERFACE CP3 CNB3 SPDIF AUDIO OUTPUT + J1 2xHDMI INPUT CNV3 1xVGA INPUT 2xCOMPOSITE INPUT CNV4 CN9 OSD FUNCTION CONTROLS CN7 1xVGA INPUT 2xCOMPOSITE INPUT AMBIENT LIGHT SENSOR CONNECTION AUDIO ADAPTOR BOARD (OPTIONAL) 23 AUDIO BOARD POWER CABLE Available Resources > Instruction Manual > Revision Control Documentation** > Firmware Upgrade Manual** > Mechanical Drawing ** Available on Request Save time and effort for your system volumetric analysis design. Inc jpg file previews. Please download at www.digitalview.com/products/sgx-1920l-lcd-controller Controller Solution Generator Already have a panel? Use this free utility to find the perfect LCD Controller to get you up and running. Visit : www.digitalview.com/csg © Digital View Group Ltd 2011 | www.digitalview.com SGX-1920L High Resolution LCD Controller Board Mechanical Drawing Connector Definitions 137.17 [5.40] 127 [5.00] J3 JB5 JB1 CP3 CNB3 101.6 [4.00] CN1 CP1 JB4 JP2 CN10 JP11 CN8 SW4 SW3 JC1 CNC1 CP2 JP4 JP13 JP14 111.82 [4.40] CN11 PP7 IR1 JB2 JB3 LED1 J2 JC2 J1 CNV3 CNV4 GND1 CN9 CN7 Description Matching Cable CN1 CN7 CN8 CN9 CN10 CN11 CP1 CP2 CP3 CNB2 CNC1 CNV3 CNV4 J1 J2 J3 LED1 Second RS-232 serial control Audio board connector RS-232 serial control Ambient light sensor connector HDMI audio (stereo) output SPDIF Audio Input Reserved Reserved Reserved Power In & Backlight Control OSD controls 1x VGA & 2x Composite Input 1x VGA & 2x Composite Input 2 x HDMI Input Additional Panel Power Output Panel Signal for LVDS Panel Dual Color LED Connector P/N 426091300-3 P/N 426454500-3 P/N 426091300-3 P/N 426031600-3 P/N 426454400-3 P/N 426007400-3 N/A N/A N/A P/N 426101100-3 P/N 426122210-3 P/N 426301400-3 P/N 426301400-3 P/N 426300900-3 Dependant on Panel Dependant on Panel P/N 426031400-3 Custom Engineering Services 13.1 [0.52] Accessories Custom input timing, panel timing, splash screen, OSD Menu, conformal coatings, layouts etc Ordering Options SGX-1920L Controller Board PR-1200 (12V Power Board) PR-2400 (24V Power Board) 1.65 [0.06] 1.75 [0.07] 5.08 [0.20] 5.08 [0.20] Ref P/N 4172600xx-3 P/N 41601961x-3 P/N 41601951x-3 HD-SDI Adaptors : Single Channel (HD-3000S) Dual Channel (HD-3000) P/N 4160164xx-3 P/N 4160160xx-3 Dual HDMI Input Cable VGA + Composite Cable IR Remote Control Audio Amplifier P/N 426300900-3 P/N 426301400-3 P/N 559000106-3 P/N 416940020-3 OSD Digital Button Board OSD Vertical Membrane OSD Horizontal Membrane Kit 67110-3 Kit 67134-3 Kit 67135-3 EUROPE 6 Marylebone Passage, London, W1W 8EX, UK t : +44 (0) 20-7631-2150 www.digitalview.com ASIA 16th Floor Millennium City 3, 370 Kwun Tong Road, Kwun Tong, Hong Kong t : (852) 2861-3615 USA 18440 Technology Drive, Morgan Hill, CA 95037, USA t : +1 (408) 782-7773 © Digital View Group Ltd 2011 | www.digitalview.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Digital View: 426300900-3 KIT 67134-3 KIT 67110-3 426007400-3 426091300-3
426091300-3 价格&库存
很抱歉,暂时无法提供与“426091300-3”相匹配的价格&库存,您可以联系我们找货
    • 1+123.998651+16.08873
    • 10+96.7427810+12.55230
    • 100+81.31532100+10.55060
