416470210-3
416470210-3
    DIGITALVIEW
    BOARD ADD-ON LVDS
416470210-3 数据手册
4164702-10 LVDS Add On Board The LVDS add-on board of P/N : 4164702-10 designs for single pixel LVDS panel. Mechanical drawing 4164702-10 Connector pin assignment : CN5 – Panel connector: HIROSE DF14-20P-1.25 PIN SYMBOL 1 VLCD 2 VLCD 3 GND 4 GND 5 /OUT00 6 OUT00 7 GND 8 /OUT01 9 OUT01 10 GND 11 /OUT02 12 OUT02 13 GND 14 /CLKOUT0 15 CLKOUT0 16 GND 17 /OUT03 18 OUT03 19 GND 20 NC CN2 – Panel connector: HIROSE DF11-28DS-2DSA PIN SYMBOL 1 GND 2 GND 3 ER2 4 OR2 5 ER3 6 OR3 7 ER4 8 OR4 9 ER5 10 OR5 11 EG2 12 OG2 13 EG3 14 OG3 15 EG4 16 OG4 17 EG5 18 OG5 19 EB2 20 OB2 21 EB3 22 OB3 23 EB4 24 OB4 25 EB5 26 OB5 27 GND 28 GND DESCRIPTION Panel power supply Panel power supply Ground Ground Negative differential LVDS data 00 Positive differential LVDS data 00 Ground Negative differential LVDS data 01 Positive differential LVDS data 01 Ground Negative differential LVDS data 02 Positive differential LVDS data 02 Ground Negative LVDS clock 0 Positive LVDS clock 0 Ground Negative differential LVDS data 03 Positive differential LVDS data 03 Ground No connection DESCRIPTION Ground Ground Even data bit R2 Odd data bit R2 Even data bit R3 Odd data bit R3 Even data bit R4 Odd data bit R4 Even data bit R5 Odd data bit R5 Even data bit G2 Odd data bit G2 Even data bit G3 Odd data bit G3 Even data bit G4 Odd data bit G4 Even data bit G5 Odd data bit G5 Even data bit B2 Odd data bit B2 Even data bit B3 Odd data bit B3 Even data bit B4 Odd data bit B4 Even data bit B5 Odd data bit B5 Ground Ground 4164702-10 CN3 – Panel connector: HIROSE DF11-32DS-2DSA PIN SYMBOL 1 NC 2 NC 3 VLCD12 4 NC 5 GND 6 GND 7 ER6 8 OR6 9 ER7 10 OR7 11 EG6 12 OG6 13 EG7 14 OG7 15 EB6 16 OB6 17 EB7 18 OB7 19 GND 20 GND 21 Vcc 22 Vcc 23 VS 24 /PwrDn 25 HS 26 DE 27 VLCD 28 VLCD 29 CLE 30 CLO 31 GND 32 GND CN4 - Hirose DF11-20DF-2DSA PIN SYMBOL 1 GND 2 GND 3 NC 4 NC 5 ER0 6 OR0 7 ER1 8 OR1 9 EG0 10 OG0 11 EG1 12 OG1 13 EB0 14 OB0 15 EB1 16 OB1 17 NC 18 NC 19 GND 20 GND DESCRIPTION No Connection No Connection 12V VLCD No connection Ground Ground Even data bit R6 Odd data bit R6 Even data bit R7 (MSB) Odd data bit R7 (MSB) Even data bit G6 Odd data bit G6 Even data bit G7 (MSB) Odd data bit G7 (MSB) Even data bit B6 Odd data bit B6 Even data bit B7 (MSB) Odd data bit B7 (MSB) Ground Ground DC +5v, reserved & not normally used DC +5v, reserved & not normally used Vertical sync Power down control signal (5V TTL) Horizontal sync Display enable Panel supply (switched) Panel supply (switched) Even dot clock (shift clock) Odd dot clock (shift clock) Ground Ground DESCRIPTION Ground Ground No connection No connection Even data bit R0 (LSB) Odd data bit R0 (LSB) Even data bit R1 Odd data bit R1 Even data bit G0 (LSB) Odd data bit G0 (LSB) Even data bit G1 Odd data bit G1 Even data bit B0 (LSB) Odd data bit B0 (LSB) Even data bit B1 Odd data bit B1 No connection No connection Ground Ground
416470210-3 价格&库存
很抱歉,暂时无法提供与“416470210-3”相匹配的价格&库存,您可以联系我们找货
