N482-3M8-LC12
N482-3M8-LC12
    TRIPPLITE
    N482-3M8-LC12
N482-3M8-LC12 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Guaranteed compatibility with recommended Tripp Lite cabling, including the N820-, N821-, N844-, N845and N858-Series cables8-fiber MTP ports are Polarity B, optimized for parallel optics and Base-8 Highlights ● For use with Tripp Lite N48201U or N482-02U chassis ● Simple installation with no tools required ● Factory-terminated OM4 connectors ● Supports 40 GbE internally using OM4 fiber optic cable ● Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 to SFP+ 10GBASE-SR and QSFP28 100GBASE-SR4 to SFP28 25GBASESR connections ● Designed for use with recommended Tripp Lite cabling Connectivity 40/100Gb Breakout Cassette, 40Gb to 4 x 10Gb, 100Gb to 4 x 25Gb (x3) 8-Fiber OM4 MTP/MPO (Male with Pins) to (x12) LC Duplex, Type-B Polarity MODEL NUMBER: N482-3M8-LC12 System Requirements ● QSFP switches that use 8-fiber per port to support 4 x LC 10 GB breakout ● Guaranteed compatibility with recommended Tripp Lite cabling, including the N820-, N821-, N844-, N845- and N858Series cables ● 8-fiber MTP ports are Polarity B, optimized for parallel optics and Base-8 Connectivity Installs in select Tripp Lite fiber enclosure panels to connect 12 LC duplex fiber cables with three 8-fiber MTP/MPO connections in high-density network applications. Package Includes Description The N482-3M8-LC12 40/100 Gb to 10/25 Gb Breakout Cassette works in tandem with Tripp Lite’s N48201U or N482-02U chassis to connect 12 LC duplex fiber cables with three 8-fiber MTP/MPO connections in high-density network applications. It’s compatible with recommended Tripp Lite cabling, including the N820-, N821-, N844-, N845- and N858-Series. Its 8-fiber MTP ports are Polarity B, optimized for parallel optics and Base-8 connectivity. This cassette also future proofs your network for eventual 50Gb and 200Gb speeds and beyond. The cassette’s modular design installs easily in the N482-01U and N482-02U chassis with no tools required. Just insert the cassette into the chassis, and snap in its retention clips to secure it. Plug LC patch cables, such as Tripp Lite’s N820-01M-T cables, into the cassette using the cable’s convenient push/pull tabs. Up to five N482-3M8-LC12 cassettes fit in the N482-01U 1U enclosure panel, and 14 cassettes fit in the N482-02U 2U chassis. Dust tabs protect unused ports from potential damage. The N482-3M8-LC12 complies with IEEE 802.3ae (10 GbE) and ANSI T11.2 (Fibre Channel) requirements. Supports 40 GbE internally using OM4 fiber optic cable. Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 to SFP+ 10GBASE-SR and QSFP28 100GBASE-SR4 to SFP28 25GBASESR connections. Ideal for QSFP fabric switches that use eight out of 12 available MTP fibers for four-lane parallel optics to 40 GB, allowing all 12 LC duplex cassette ports to be used. Maximum insertion loss of 0.35 dB falls well under the IEEE 802.3ae maximum channel loss specification of
N482-3M8-LC12 价格&库存
很抱歉,暂时无法提供与“N482-3M8-LC12”相匹配的价格&库存,您可以联系我们找货
