N482-3M8L12S-B
N482-3M8L12S-B
    TRIPPLITE
    N482-3M8L12S-B
N482-3M8L12S-B 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Guaranteed compatibility when used with recommended Tripp Lite cabling. Designed specifically for use with Tripp Lite cables, such as the N370-series cables. 40/100Gb Fiber Breakout Cassette with Built-In MTP Cables, 40Gb to 4 x 10Gb, 100Gb to 4 x 25Gb, (x3) 8-Fiber Singlemode MTP/MPO to (x12) LC Duplex 9/125 Highlights ● For use with Tripp Lite N48201U or N482-02U chassis ● 3 yellow built-in 2-meter 8-fiber MTP singlemode cables ● Guaranteed compatibility when used with recommended Tripp Lite cabling ● Designed specifically for use with Tripp Lite cables, such as the N370-series cables ● Factory-terminated connectors ● Supports 40 GbE internally using fiber optic cable ● Simple installation with no tools required MODEL NUMBER: N482-3M8L12S-B System Requirements Installs in select Tripp Lite fiber chassis to connect 12 LC duplex fiber cables with three 8-fiber MTP/MPO connections in high-density network applications. ● QSFP switches that use 8-fiber per port to support 4 x LC 10 GB breakout ● Guaranteed compatibility when used with recommended Tripp Lite cabling ● Designed specifically for use with Tripp Lite cables, such as the N370-series cables Package Includes ● N482-3M8L12S-B 9/125 Fiber Breakout Cassette ● Owner’s manual Description The N482-3M8L12S-B 9/125 Fiber Breakout Cassette works in tandem with Tripp Lite’s N482-01U or N482-02U chassis to connect 12 LC duplex fiber cables with three 8-fiber MTP/MPO connections in highdensity network applications. The cassette features three built-in 2-meter 8-fiber MTP cables. Color-coded yellow singlemode cables are easily distinguished from traditional aqua OM3 multimode fiber. The cassette’s modular design installs easily in the N482-01U and N482-02U chassis with no tools required. Just insert the cassette into the chassis, and screw in its retention clips to secure it. Plug LC patch cables, such as Tripp Lite’s N370-series cables, into the cassette. Up to five N482-3M8L12S-B cassettes fit in the N482-01U 1U enclosure panel, and up to 14 cassettes fit in the N482-02U 2U sleeve. Dust tabs protect unused ports from potential damage. Guaranteed compatibility when used with recommended Tripp Lite cabling. Designed specifically for use with Tripp Lite cables, such as the N370series cables. The N482-3M8L12S-B complies with IEEE 802.3ae (10 GbE) and ANSI T11.2 (Fibre Channel) requirements. Supports 40 GbE internally using 9/125 singlemode fiber optic cable. Ideal for QSFP fabric switches that use eight out of 12 available MTP fibers for four-lane parallel optics to 40 GB, allowing all 12 LC duplex cassette ports to be used. Maximum insertion loss of 0.35 dB falls well under the IEEE 802.3ae maximum channel loss specification of
N482-3M8L12S-B 价格&库存
很抱歉,暂时无法提供与“N482-3M8L12S-B”相匹配的价格&库存,您可以联系我们找货
