ZCTR-03-RGB
ZCTR-03-RGB
    JKLCOMPONENTS
    LED CONTROLLER
ZCTR-03-RGB 数据手册
The LED RGB Controller is designed for LED lighting color control. It can control modules, LED ribbons, LED bars, High Power LED modules and other LED lighting fixtures. FEATURES • • • • • Power Off Memory 11 Control Modes Rate Control for Cycling Color Changes and Brightness Control Common Anode CMOS Outputs Operates up to 8 JKL LED Light Bars, reference P/N ZRS-10573-RGB MODES RATINGS CHARACTERISTICS Input Voltage Load Current Operating Temperature UNIT Volts DC Amps degrees C MINIMUM -20 TYPICAL 12 4 MAXIMUM 6 60 MODE # 1 2 3 4 5 6 7 8 9 10 TITLE Static Red Static Blue Static Violet Static Green Static Yellow Static Cyan Static White Flash Cycle #1 Flash Cycle #2 Gradual Cycle #1 11 Gradual Cycle #2 DESCRIPTION The "R" output is constantly ON The "B" output is constantly ON The "R and G" output is constantly ON The "G" output is constantly ON The "R and G" outputs are constantly ON The "G, and B" outputs are constantly ON The "R, G, and B" outputs are constantly ON The "R, B, and G" outputs go ON and OFF in order All the static colors come ON and OFF in a sequence The "R, G, and B" output go ON and OFF in order with overlap between colors (Brightness adjust Not Available) All the static colors come ON and OFF in a sequence with overlap between colors (Brightness adjust Not Available)
ZCTR-03-RGB 价格&库存
很抱歉,暂时无法提供与“ZCTR-03-RGB”相匹配的价格&库存,您可以联系我们找货
