PCR_740
PCR_740
    VCC
    LED SOCKET 5MM RA PCB
PCR_740 数据手册
VISUAL COMMUNICATIONS COMPANY, INC. 7920-G Arjons Dr., San Diego, CA 92126 In CA (619) 549-6900 (800) 522-5546 FAX (619) 549-3520 www.vcclite.com PCB MOUNT FOR BI/TRI-LEAD LEDs FEATURES • Right angle PCB mount for bi and tri-lead LEDs for use as logic and diagnostic indicators • Accommodates round and rectangular shapes of LEDs with or without flanges • Dove-tail interlock feature allows mounting of both mono and multi-colored LEDs PCB MOUNTING OF BI & TRI-LEAD LEDs U.S. & For. Pat. Issued & Pend. • Mount forms LED leads which are locked into position by retaining tabs • Formed LED leads are staggered in their length permitting easier PCB insertion • Molded standoffs permit the easy cleaning of PCB after wave solding operation PCB MOUNTING OF LEDs IN ARRAYS VCC VCC PAT PEND PAT PEND OUTLINE DRAWINGS 45° Form leads with the mount, snap leads into retaining tabs. .200 (5.08mm) Bi-lead and tri-lead LEDs can be combined with dove-tail interlocking feature. POLARITY REF. SPECIFICATIONS .100 MATERIALS: Housing – Thermoplastic (black) U.L. 94 V0. PCB HOLE PATTERN (2.54mm) .080 .020 MOUNTING: PCH 175 – Right angle ThruThe-Hole mount for LEDs. Can be used as a single LED mount or banded together in an array with its dove-tail interlocking feature. (.51mm) .248 (6.30mm) .100 .100 (2.54mm) (2.54mm) .050 (1.27mm) .050 (1.27mm) .125 (6.30mm) MODEL LED: 5mm size - round or rectangular shape with or without flange. Bi-lead, standard .100" lead spacing. Tri-lead, either .050" or .100" lead spacing. Both the bi-lead and tri-lead LEDs can also be combined in arrays with one another. .010 TYP. .050 PCH 175 When banded together with the PCH 175 the LEDs are on .250" centers. .248 (3.18mm) ORDERING CODES (2.03mm) (.25mm) (1.27mm) .100 (2.54mm) .220 (5.59mm) .350 (8.89mm) PCB MOUNTS FOR 3mm & 5mm LEDs FEATURES U.S. & For. Pat. Issued & Pend. OUTLINE DRAWINGS (12.70mm) .20 (5.08mm) .05 .010 (1.27mm) (.25mm) .20 DIA. .24 SQ. (5.08mm) (6.10mm) .18 DIA. (4.57mm) .010 (.25mm) .100 .190 (2.54mm) (4.83mm) .73 PCR 740 (18.54mm) .100 (2.54mm) .010 .06 (.25mm) (1.52mm) .22 (5.59mm) .2 .35 SQ. (7 (8.89mm) .010 (.25mm) .100 .50 (2.54mm) (1.27mm) .100 (2.54mm) .230 (5.84mm) RECOMMENDED LEDs See Cliplite Lens Data Page. Page 16 • Height compatible with switches and other circuit board mounted components • Stabilizes LED during packaging and physically protects after assembly • Increases LED apparent brightness and viewing angle up to 180 degrees • Mounts flush, recessed or fully extended thru display panel without attachments • Guards against IC damage by electrostatic discharge transmitted thru exposed LED HORIZONTAL MOUNT VERTICAL AMOUNT Snap LED into lense – insert LED leads through holes in mount base – close mount, bending leads into position. Snap LED into lense – insert LED leads through holes in mount base – close mount. SPECIFICATIONS .50 PCL 490 • Wave solders horizontally or vertically without special jigs or fixtures MATERIAL Body – General Purpose Nylon (U.L. Listed Materials). Lens – Polycarbonate (U.L. Listed). MOUNTING P C board, horizontally or vertically on .100 inch hole centers. 3mm (PCL 490 with SML 190) panel thickness from 1/64" to 3/16" thru a 7/32" clearance hole. 5mm (PCR 740 with CLF 280) panel thickness from 1/32" to 9/32" thru a 5/16" clearance hole. CLP series of the CLIPLITE clipmounts may also be used. Permits flush mounting to full projection of the lens portion thru the panel. LEDs Standard LEDs, diffused or nondiffused. See drawings. No attempt should be made to bend a lead with a stepped thickness. ORDERING CODES PCL 490 MODEL (BODY) PCL 490 (3mm) PCR 740 (5mm) SML 190 RTP MODEL (LENS) SML 190 (3mm) CLF 280 (5mm) COLOR RTP GTP ATP YTP CTP BTP Red Transparent Green Transparent Amber Transparent Yellow Transparent Clear Transparent Blue Transparent
PCR_740 价格&库存
很抱歉,暂时无法提供与“PCR_740”相匹配的价格&库存,您可以联系我们找货
