1091M5-125VAC
1091M5-125VAC
    VCC
    LED IND LIGHT GREEN 125V SNAPFIT
1091M5-125VAC 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 1091M Series Non-Relampable LED Indicator Lights Description and Features All dimensions in inches. Solid-state indicator lights complete with built-in current-limiting resistor and rectifier diode. Ø.630 Mounting: Will snap-fit into Ø.500/.505 hole in panels .020/.100 thick. Push-on speednut SN0461 also available. Mounting hole pattern on page SP2. .380 Wire Leads: No. 22 AWG (105°C) 4.40/4.80 long, stripped .430/.570 1.130 Lens: Polycarbonate Anode(+): Red lead Ø.500 MAX. Bezel: Polished stainless steel. Housing: White Nylon Lens C olor R ed G reen Y ellow Internal R es is tor (ohms ) Model No. (6V ) 1091M1-6V 1091M5-6V 150 LE D Solid S tate Model No. (12V ) 1091M1-12V 1091M5-12V 1091M7-12V 390 V oltage T able Nominal 6V 12V 24V 125 V AC V AC 5 to 11 10 to 20 22 to 32 105 to 125 Indicator Model No. (24V ) 1091M1-24V 1091M5-24V 1091M7-24V 1000 Lens C olor VD C 3.5 to 6.5 6 to 13.5 12 to 24 - Model No. (105-125 V AC *) 1091M1-125V AC 1091M5-125V AC 1091M7-125V AC (2) 3.9K 1/2W* (One Internal) Incorporates LE D* R ed 4304H1 G reen 4304H5 Y ellow 4304H7 *125 VAC supplied with 6" white wire, stripped 1/2" with external 3.9K 1/2 watt resistor attached to one lead, covered with shrink tubing insulation. * Also incorporates 1N4004 (400 P.I.V.) rectifier diode. To use 24V model: Beyond 32VAC add 30 ohms per volt; beyond 24 VDC add 50 ohms per volt. Use 1/2W resistor up to 50V; 1W resistor for 50V to 70V; 2W resistor for 75V to 125V. Do not use beyond 125V. CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
1091M5-125VAC 价格&库存
很抱歉,暂时无法提供与“1091M5-125VAC”相匹配的价格&库存,您可以联系我们找货
1091M5-125VAC
    1091M5-125VAC
    • 1+89.280201+11.53940
    • 10+68.1757810+8.81167
    • 100+55.83913100+7.21717
    • 500+50.46525500+6.52260
    • 1000+48.720971000+6.29715
    库存:2821
