5110F Series Panel Mount
LED Indicator Light for
mounting hole 0.157” (4.0mm)
Press fit round indicator light for super bright
LED T-1 (3 mm)
Applications
panel indication
electrical panels
entertainment
industrial
appliances
displays
Key features
super bright T-1 (3mm) LED
include low current option (2mA)
4 colors available: red, green, yellow, amber
voltage options: 2, 5 or 12V
volt supply, no external resistor needed.
• recommended the use of an installation tool to
Product dimensions
Ø.190
[Ø 4.8]
LED T-1
.190 max
[4.8 max]
.41
[4.8]
.03
[0.8]
Ø.157”
[Ø 4.0]
Housing
Mounting Hole
Wire Leads
Dimensions in
inches [mm]
engineered to light up your design
www.vcclite.com
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
1.800.522.5546
07/15 Rev 1
Product specifications and ordering data
Electro-optical Characteristics
12V
5V
Low Current
Standard
Part
Number
Color
Typ.
Intensity
Rated
Current
(mcd)
(mA)
Continuous
Foward
Current
Max. (mA)
Forward
Voltage
Typ. (V)
Forward
Voltage
Max.
(V)
Peak Forward Reverse
Current @ Break-down
1ms- 300pps Voltage Min.
(V)
(A)
Peak
Wavelenght
(nm)
5110F1
Red
10.0
10
30
2.0
3.0
1.0
5
635
5110F5
Green
16.0
2.2
3.0
0.09
4
562
5110F7
Yellow
6.3
2.1
3.0
1.0
5
585
5110F1LC
Red
2.5
2
7
1.8
2.2
0.007
5
635
5110F5LC
Green
2.1
2
7
1.8
2.2
0.007
5
565
5110F7LC
Yellow
1.8
2
7
1.9
2.7
0.007
5
583
5110F1-5V
Red
8.0
10
7.5
5
655
5110F3-5V
Amber
8.0
10
15
5
7.5
5
583
5110F5-5V
Green
8.0
10
15
5
7.5
5
565
5110F1-12V
Red
8.0
13
15
5
655
5110F3-12V
Amber
8.0
13
15
5
583
5110F5-12V
Green
8.0
13
15
5
565
Material
Housing
Wire Leads
Operating parameters
Operating
temperature
Installation specification
Nylon (Black)
0.009” (0.23mm) Wall PVC,
Red (Anode), Black (Cathode)
Mounting hole
Panel thickness (minimum)
0.155/0.158” (3.94/4.01mm)
0.031/0.062” (0.79/1.58mm)
Wire leads
4.4” (111.8) min. long,
#26 AWG, stripped 0.250”
Anode (+)
Red lead
-13°F (-25°C) to
185°F (85°C)
Compliance & approvals
www.vcclite.com
1.800.522.5546
07/15 Rev 1
很抱歉,暂时无法提供与“5110F5-5V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+48.608681+6.29189
