5111F1-5V
5111F1-5V
    VCC
    LED Panel Indicator Red Diffused 5V 15mA Round with Domed Top, 3mm (T-1)
5111F1-5V 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5111F Series Panel Mounted LED Indicator Light Description and Features Features • Super Brite T-1 LED • Diffused lens allows wide angle viewing. • Low current -only 2 mA. • Built -in chip resistor operates directly off 5 volt supply, no external resistor needed. .19 .19 MAX. .03 Mounting: Will snap-fit into Ø.155/.158 hole in panels .031/.062 thick* .32 Terminals: .020 sq. WIR E WR AP P AB LE LE ADS .20 MIN. Housing: Black Nylon *W e recommend using an installation tool to press against flange of housing rather than LED. .02 S Q.T Y P . .10 ANODE (+) F LAT OR IE NT E D T O P LUS S IG N AS S HOWN All dimensions in inches. Electro-optical Characteristics Part Number Color Ty p. Intensity (mcd) Rated Current (mA) Continuous Forward Forward Peak Forward Forward Current Max. Voltage Typ.Voltage Max. Current @1 ms(V) (V) 300pps (A) (mA) 30 1.0 2.0 3.0 Reverse Break-down Peak Voltage Min. Wavelength (nm) (V) 5 650 5111F1 Red 10 10 5111F5 Green 16 10 30 2.2 3.0 .09 4 562 5111F7 Yellow 6.3 10 30 2.1 3.0 1.0 5 585 5111F1LC Red 2.5 2 7 1.8 2.2 .007 5 635 5111F1-5V Red 8.0 10 15 5 7.5 - 5 635 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5111F1-5V 价格&库存
很抱歉,暂时无法提供与“5111F1-5V”相匹配的价格&库存,您可以联系我们找货
