2332QD5
2332QD5
    VCC
    Neon Panel Indicator Green 105 V ~ 125 V Rectangle with Flat Top Quick Connect - 0.187" (4.7mm)
2332QD5 数据手册
TM 2330QD, 2332QD and 2390QD Series Non-Relampable Neon-Incandescent Indicator Lights Rectangular Neon-Incandescent Quick Connect Terminals Indicator Lights for 0.400” x 1.280” mounting hole Specifications Mounting: Will snap-fit into cut-out 0.400” x 1.280“ and will mount in .032” - .100” thick panels Terminals: Quick-connect, tinned brass, 0.250” Lens: Polycarbonate Bezel: Stainless steel. Underwriters Laboratories (UL) File No. E20356 Ordering Information Lens C olor Neon Incandescent (105 - 125 VAC) (28 VAC/VDC) Part No. Part No. R ed 2330Q D1 2390Q D1-28V Amber 2330Q D3 2390Q D3-28V White 2330Q D4 2390Q D4-28V G reen 2332Q D5* 2390Q D5-28V Lamp us ed C 6 A+Res is tor Lamp #: 2187 *Incorporates G2B lamp and resistor your first call for illuminated components www.vcclite.com 1  1.800.522.5546 03/17 Rev 2 Dimensions .190 [4.83] .130 MAX [3.30] .430 [10.92] 1.270 [32.26] .250 [6.35] TERMINALS MOUNTING HOLE 1.280 [32.51] 0.400 [10.16] All dimensions in inches [mm]. Compliances and Approvals your first call for illuminated components www.vcclite.com 2 1.800.522.5546 03/17 Rev 2
2332QD5 价格&库存
很抱歉,暂时无法提供与“2332QD5”相匹配的价格&库存,您可以联系我们找货
