Ruggedized LED
Panel Mount Indicator
CNX 480 and 482 Series offer a robust anodized aluminum
body delivering NEMA 4 protection from the elements
Applications
instrument panels
disinfection and sterilization environments
transportation dashboards
safety applications
outdoor signage
aircraft and military
industrial machinery
electrical control panels
vending and gaming machines
resistant to shock and vibration
ESD protection
custom LEDs, lens and body colors available
RoHS compliant
Key features
designed for harsh and outdoor environments
wide angle viewable
low profile for anti-vandalism
direct sunlight visibility
Dimensions
CNX480 without moisture-seal
CNX482 with moisture seal
engineered to light up your design
www.vcclite.com
1.800.522.5546
Product specifications
LED output
typ intensity,
mcd
245-345
345-485
3500-4900
950-1300
280-380
LED color**
red
green
white
blue
yellow
socket body
lens
washer
retaining nut
wire
moisture seal
forward voltage,
V (typ)
1.8
1.9
2.8
3.0
1.9
Installation specification
mounting hole .399±.004 (10.1mm±.1)
panel
.059(1.5mm) min to
thickness
.320 (8.1mm) max
Materials
aluminum alloy
polycarbonate, UL rating 94-V2
steel, zinc plated, UL rating
94-V0
aluminum alloy
24 AWG 1007/1569
red = anode(+)
black = cathode (-)
EPDM
Operating parameters
operating
-40°F (-40°C) to
temperature
176°F (80°C)
LED output
20mA
current
Ordering data
CNX 48X X XXX XX
CNX 480/482 cable assembly
ordering code (example)
CNX480 std-no/seal
CNX482 moisture sealed
Socket body
anodized finish
1
black
2
clear
RTP
GTP
CTP
BTP
YTP
Lens color**
red transparent
green transparent
clear transparent
blue transparent
yellow transparent
Wire length code
12
12.0” 305mm
24
24.0” 610mm
**LED color same as the lens color.
Example: Red LED comes with a red lens.
www.vcclite.com
1.800.522.5546
很抱歉,暂时无法提供与“CNX_482_1_GTP_12”相匹配的价格&库存,您可以联系我们找货
