5400A1
5400A1
    VCC
    LED RED 5/16" HOLE PANEL MOUNT
5400A1 数据手册
5400 Series Ø 0.315" (8.0 mm) Panel Mount LED Indicator A unique design, the 5400 Series is a two-piece unit consisting of a lens and the housing-LED assembly. Simple, fast installation. Available in 4 colors: Red, Amber, Green and Yellow. Applications • Industrial • People Movers • Electro medical devices and systems • Appliances • Transportation and Infrastructures • Food Services and Industries Key Features • Simple and fast installation • Low profile, damage-resistant lens • Discharge protection • • • • 8 mm panel mounting LED Indicator 5 mm colored polycarbonate lens Unique design in a two piece unit Wide-angle viewing Installation Instructions The panel mount LED indicator light consists of one lens and one body in lead wires terminations. The fast installation is provided by inserting the lens into mounting hole in the front display panel and snapping the housing assembly onto the lens from the rear. Allows pre-wiring into the circuit and testing before installation. Product Specifications Installation and Operating Specifications Material Housing Natural Nylon Mounting Hole Lens Polycarbonate Panel Thickness Wire Leads 24 AWG PVC (105o C) 4.4/4.8” long, stripped .430/.570” engineered to light up your design Operating Temperature Anode (+) www.vcclite.com CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. .312/.317” (7.9/8.1mm) .062 to .125” (1.6 to 3.2 mm) -25 oC/+85 oC -13 oF/+185 oF Red Lead 1.800.522.5546 08/15 Rev 1 Product Dimensions Body: Lens: .910 MAX [23.1 MAX] .380 Ø [9.7] Low Profile PANEL LIGHT DIFFUSING RINGS Lens .030 [0.7] .330 [8.4] Ø .380 [9.7] .680 Ref. [17.3 Ref.] Ø.270 [6.9] Ø.310 [7.9] .090 [2.3] All dimensions in inches [mm] Ordering Data Electro-optical Characteristics Part Number Color Typ. Intensity (mcd) Rated Current (mA) Continuous Forward Current Max. (mA) Forward Voltage Typ. (V) Forward Voltage Max. (V) Current @ 1msReverse Peak Forward Break-down 300pps (A) Voltage Min. (V) Include Lens Model No. 5400A1 Red 120 20 35 2.0 3.0 1.0 5 4741 5400A3 Amber 120 20 35 2.0 3.0 1.0 5 4743 5400A5 Green 120 20 20 2.1 2.5 - 4 4745 5400A7 Yellow 120 20 35 2.1 3.0 1.0 5 4747 Compliance & approvals engineered to light up your design www.vcclite.com CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 08/15 Rev 1
5400A1 价格&库存
很抱歉,暂时无法提供与“5400A1”相匹配的价格&库存,您可以联系我们找货
