engineered to light up your design
www.vcclite.com
1.800.522.5546
5111F Series Panel Mounted LED Indicator Light
Description and Features
Features
• Super Brite T-1 LED
• Diffused lens allows wide angle viewing.
• Low current -only 2 mA.
• Built -in chip resistor operates directly
off 5 volt supply, no external resistor needed.
.19
.19 MAX.
.03
Mounting: Will snap-fit into Ø.155/.158 hole
in panels .031/.062 thick*
.32
Terminals: .020 sq.
WIR E
WR AP P AB LE
LE ADS
.20 MIN.
Housing: Black Nylon
*W e recommend using an installation tool to press
against flange of housing rather than LED.
.02 S Q.T Y P .
.10
ANODE (+)
F LAT OR IE NT E D
T O P LUS S IG N
AS S HOWN
All dimensions
in inches.
Electro-optical Characteristics
Part
Number
Color
Ty p.
Intensity
(mcd)
Rated
Current
(mA)
Continuous
Forward
Forward
Peak Forward
Forward
Current Max. Voltage Typ.Voltage Max. Current @1 ms(V)
(V)
300pps (A)
(mA)
30
1.0
2.0
3.0
Reverse
Break-down Peak
Voltage Min. Wavelength
(nm)
(V)
5
650
5111F1
Red
10
10
5111F5
Green
16
10
30
2.2
3.0
.09
4
562
5111F7
Yellow
6.3
10
30
2.1
3.0
1.0
5
585
5111F1LC
Red
2.5
2
7
1.8
2.2
.007
5
635
5111F1-5V
Red
8.0
10
15
5
7.5
5
635
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“5111F7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.717161+1.51246
- 10+8.2696110+1.06745
- 100+6.17769100+0.79742
