6010M3
6010M3
    VCC
    INDICATOR NEON AMBER PANEL MNT
6010M3 数据手册
6010M, 6011M, 6012M, 6013M and 6091M Series Oil-Tight Non-Relampable Neon-LED Indicator Lights Description and Features All dimensions in inches (mm) .38 (9.7) Solid-state indicator lights complete with built-in current-limiting resistor and rectifier diode. Ø.63 (16.0) Ø.39 (9.9) Meets NEMA Class 13 Mounting: Ø.380(9.65) hole. Supplied with internal tooth lock washer and hex nut. .11(2.8) Wire Leads: Neon Models: No. 18 AWG (105°C) 4.4 (111.8)/4.8 (121.9) long, stripped .43 (10.9)/.57 (14.5) LED Models: No. 22 AWG (105°C) 4.4 (111.8)/4.8 (121.9) long, stripped .43 (10.9)/.57 (14.5) O-RING (SUPPLIED) .50 (12.7) 3/8-24 THREAD 1.60 (40.6) Lens: Polycarbonate Bezel: Polished stainless steel. Gaskets: Buna-N Housing: Black Nylon BASE: POLYCARBONATE Mounting Hole: "D" flat is optional Panel Thickness: .03 (.8)/.25 (6.4) .375 (9.53)/.380 (9.65) .350 (8.89)/.355 (9.02) Neon Indicator Lens Color Model No. Model No. LED Solid State Indicator Lens Color Model No. Model No. Incorporates LED** (105-125VAC) (208-250VAC) for 12V for 24V Red 6010M1 6011M1 Red 6091M1-12V 6091M1-24V 4304H1 Amber 6010M3 6011M3 Green 6091M5-12V 6091M5-24V 4304H5 Green 6012M5* 6013M5* Yellow 6091M7-12V 6091M7-24V 4304H7 Internal Resistor (ohms) 390 Lamp used C2A+Resistor C2A+Resistor Lamp Color Black 1 Black/1 Red * Incorporates G2B lamp and resistor. Underwriters Laboratories (UL) File No. E20356 engineered to light up your design 1000 - **Note: Also incorporates IN4004 (400 P.I.V.) rectifier diode. Red lead positive. www.vcclite.com 1.800.522.5546 02/15 Rev 1
6010M3 价格&库存
很抱歉,暂时无法提供与“6010M3”相匹配的价格&库存,您可以联系我们找货
6010M3
