CNX_482_2_RTP_12
CNX_482_2_RTP_12
    VCC
    PMTINDCTRMSCLRANDZDALUMRED
CNX_482_2_RTP_12 数据手册
Ruggedized LED Panel Mount Indicator CNX 480 and 482 Series offer a robust anodized aluminum body delivering NEMA 4 protection from the elements Applications • • • • • instrument panels disinfection and sterilization environments transportation dashboards safety applications outdoor signage • • • • aircraft and military industrial machinery electrical control panels vending and gaming machines • • • • resistant to shock and vibration ESD protection custom LEDs, lens and body colors available RoHS compliant Key features • • • • designed for harsh and outdoor environments wide angle viewable low profile for anti-vandalism direct sunlight visibility Dimensions CNX480 without moisture-seal CNX482 with moisture seal engineered to light up your design www.vcclite.com 1.800.522.5546 Product specifications LED output typ intensity, mcd 245-345 345-485 3500-4900 950-1300 280-380 LED color** red green white blue yellow socket body lens washer retaining nut wire moisture seal forward voltage, V (typ) 1.8 1.9 2.8 3.0 1.9 Installation specification mounting hole .399±.004 (10.1mm±.1) panel .059(1.5mm) min to thickness .320 (8.1mm) max Materials aluminum alloy polycarbonate, UL rating 94-V2 steel, zinc plated, UL rating 94-V0 aluminum alloy 24 AWG 1007/1569 red = anode(+) black = cathode (-) EPDM Operating parameters operating -40°F (-40°C) to temperature 176°F (80°C) LED output 20mA current Ordering data CNX 48X X XXX XX CNX 480/482 cable assembly ordering code (example) CNX480 std-no/seal CNX482 moisture sealed Socket body anodized finish 1 black 2 clear RTP GTP CTP BTP YTP Lens color** red transparent green transparent clear transparent blue transparent yellow transparent Wire length code 12 12.0” 305mm 24 24.0” 610mm **LED color same as the lens color. Example: Red LED comes with a red lens. engineered to light up your design www.vcclite.com 1.800.522.5546
CNX_482_2_RTP_12
1. 物料型号:CNX 480(无防潮密封)和CNX 482(带防潮密封)。 2. 器件简介:这些LED指示器设计用于恶劣和户外环境,具有宽视角可视性、低轮廓防破坏性、直射阳光下可见性、抗冲击和振动、ESD保护,并可提供定制的LED、透镜和机身颜色,符合RoHS标准。 3. 引脚分配:文档中没有明确提供引脚分配信息,但提到了正极(+)和负极(-)的导线。 4. 参数特性: - LED颜色:红色、绿色、白色、蓝色、黄色,每种颜色都有特定的典型强度和正向电压。 - 安装规格:安装孔径、面板厚度。 - 操作参数:工作温度范围、LED输出电流。 - 材料:包括插座体、透镜、垫圈、紧固螺母、导线和防潮密封的材料。 5. 功能详解:适用于仪表板、消毒和灭菌环境、运输仪表盘、安全应用、户外标志、飞机和军事、工业机械、电气控制面板、自动售货机和游戏机等。 6. 应用信息:适用于需要耐候性和户外使用的环境。 7. 封装信息:包括尺寸、材料和订购数据,例如电缆组件的订购代码示例。
CNX_482_2_RTP_12 价格&库存
很抱歉,暂时无法提供与“CNX_482_2_RTP_12”相匹配的价格&库存,您可以联系我们找货
