2994
2994
    ADAFRUIT
    RETAINER COIN CELL 4.8MM SMD
2994 数据手册
Tower Light - Red Alert Light with Buzzer 12VDC PRODUCT ID: 2994 DESCRIPTION - THE REACTOR'S MELTING DOWN! GRAB THE FUEL CORE, JENNA, AND EVACUATE THE COMMAND CENTER! With this flexible Red Alert Light you can monitor the status of a project, machine, or even if the bathroom is occupied! We got some really nice tower lights here, first up they come in slimming Adafruit black, they're easy to attach with mounting holes, and you can rotate the light mount so it can be horizontal, vertical or any angle in between (180 rotation). This is the one color version - Red - but we also have a Red Yellow Green Alert Light in the store if you want more versatility! Alert tower lights are really easy to use. The brown wire is the common +12V power line, then the other wires are connected to ground to activate the LED light or buzzer. The red wire controls the red LED light and the orange wire is what controls the buzzer which will sound continuously when the wire is grounded. You will need a 12VDC power supply to get it going, the one that we carry will do well for fixed installations. If you are using this with a 3V or 5V microcontroller or computer, use 2 x NPN transistors or N-channel mosfets to sink current from each wire. Our guide on analog LED strips is pretty much the same wiring you need, except its only about 50mA per segment. If you desperately need something that can run off of 5V you might consider wiring up your own white LEDs instead of using the LEDs that come with it. Note: Shipping weight reflects UPS' new dimensional weight regulations. https://www.adafruit.com/products/2994 2/24/2016 Technical Details Range of motion: 180° Height: 252mm / 9.9" Diameter of light: 50mm / 1.97" Weight: 162g
2994
- 物料型号:2994 - 器件简介:这是一个灵活的红色警报灯,带有蜂鸣器,适用于监控项目、机器状态或甚至卫生间的使用情况。 - 引脚分配:棕色线是公共的+12V电源线,其他线连接到地线以激活LED灯或蜂鸣器。红线控制红色LED灯,橙色线控制蜂鸣器。 - 参数特性:运动范围为180°,高度为252mm(9.9英寸),灯的直径为50mm(1.97英寸),重量为162克。 - 功能详解:需要12V直流电源供电,如果与3V或5V的微控制器或计算机一起使用,可以使用2个NPN晶体管或N沟道MOSFET来从每根线中汲取电流。 - 应用信息:适用于固定安装,如果需要5V运行,可以考虑使用自己的白色LED代替附带的LED。 - 封装信息:文档中未提供封装信息
很抱歉,暂时无法提供与“2994”相匹配的价格&库存,您可以联系我们找货
