ITEM
1
2
3
4
Q'TY
1
1
1
1
PART NUMBER
REV.
PART DESCRIPTION
PM3
3GD
BWS24-1061-RD
BWS24-1061-BK
A
LED holder, Panel Mount, Press Fit (3mm)
T-1 (3mm) Non-Flange LED
24AWG Wire Lead U.L. 1061, RED
24AWG Wire Lead U.L. 1061, BLACK
DESCRIPTION
DATE
Engineering Release.
APPROVED
02/06/06
M. C.
6.0[152.4mm]±.250
0.140 [3.6mm]
0.420 [10.7mm]
0.030 [0.8mm]
Ø.118 [Ø3.0mm]
LED
2
0.250 [6.4mm]
Ø.190 [Ø4.8mm]
Flange
Ø.155 [Ø3.9mm]
Body
4
0.11 [2.8mm]
1
3
Ø.160+.003
-.002
Recommended Mounting Hole
LED
Part No.
3GD
Material
GaP/GaP
Chip
Peak Wave
Length
lp(nm)
565
Absolute Maximum Ratings
Lens Appearance
Emitted Color
GREEN
DIFFUSED
ABSOLUTE MAXIMUM RATINGS (Ta = 25°C)
Dl
(nm)
Pd
(mW)
If
(mA)
Peak If
(mA)
30
80
30
150
5V
REVERSE CURRENT ( VR=5V)
100 µA
OPERATING TEMPERATURE RANGE
-25°C ~ 85°C
STORAGE TEMPERATURE
-30°C ~ 100°C
LEAD SOLDERING TEMPERATURE (1/16" FROM BODY)
260°C for 5 Seconds
2.2
2.6
Viewing
Angle
(Deg)
30
45
DIST.: TOKIWA/SAGAWA
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
REVERSE VOLTAGE
Electro-Optical Data @ 20mA
Vf
lv
(V)
(mcd)
Typ.
Typ.
Max.
.X
± .1
.XX
± .02
.XXX ± .010
DESIGNED:
Sonny Dam
CHECKED:
T. Yin
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
02/06/06
DATE:
02/06/06
FAX: (949) 951-3974
T-1 (3mm) Panel Mount
REVISION:
PART NO:
PM3GDW6
CAGE CODE : 32559
A
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“PM3GDW6”相匹配的价格&库存,您可以联系我们找货
