PM5GD12VW6
PM5GD12VW6
    BIVAR
    PNL MNT 20MA GREEN W/WIRE 6"
PM5GD12VW6 数据手册
ITEM Q'TY PART NUMBER REV. PART DESCRIPTION 1 1 PM5-12V LED Holder, Panel Mount, Press Fit, (5mm) 2 1 5XX12V T-1¾ (5mm) Non-Flange LED, See Page 2. 3 1 BWS24-1007-RD 24AWG Wire Lead U.L. 1007, Red 4 1 BWS24-1007-BK 24AWG Wire Lead U.L. 1007, Black A DESCRIPTION DATE Engineering Release X +0.20 -0.05 0.190 [4.8mm] 0.030 [0.8mm] APPROVED 02/01/05 M. C. Ø.280 [Ø7.1mm] Flange 0.530 [13.5mm] 0.25 [6.4mm] Solid 12v 0.12 [3.0mm] Ø.190 [Ø4.8mm] LED 2 1 Ø.250 +.003 -.002 3 4 Ø.245 [Ø6.2mm] Body EXAMPLE: PM5RD12VW6.5* Wire Length "X" LED Color & Lens Appearance. Series Recommended Mounting Hole * X.X = Wire Length "X" ABSOLUTE MAXIMUM RATINGS (Ta = 25°C) STANDARD TOLERANCE DECIMALS REVERSE VOLTAGE 5V REVERSE CURRENT ( VR=5V) 100µA OPERATING TEMPERATURE RANGE -40°C ~ 85°C STORAGE TEMPERATURE -40°C ~ 100°C LEAD SOLDERING TEMPERATURE (1/16" FROM BODY) 260°C for 5 Seconds  ( UNLESS OTHERWISE SPECIFIED ) .X ± .1 .XX ± .02 .XXX ± .010 DESIGNED: David Green CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 02/01/05 DATE: 02/01/05 FAX: (949) 951-3974 T-1 ¾ (5mm) PANEL MOUNT ASSEMBLY, 12V REVISION: PART NO: PM5XX12VWX.X CAGE CODE : 32559 A SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DESCRIPTION DATE APPROVED SEE SHEET#1. LED Assy. No. PM5GC12VWX.X PM5GD12VWX.X PM5YC12VWX.X PM5YD12VWX.X PM5HC12VWX.X PM5HD12VWX.X PM5RC12VWX.X PM5RD12VWX.X Peak Wave Length l p(nm) 565 565 585 585 635 635 700 700 Emitted Color GREEN GREEN YELLOW YELLOW HE RED HE RED RED RED Lens Appearance WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED Electro-Optical Data @ 12V If (mA) TYP 10 10 10 10 10 10 10 10 Vf (V) TYP - MAX 12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 Viewing Angle Iv 2U ½ (mcd) (Deg) TYP 65.0 30 35.0 45 55.0 30 35.0 45 100.0 30 35.0 45 18.0 30 4.5 45 LED P/N 5GC12V 5GD12V 5YC12V 5YD12V 5HC12V 5HD12V 5RC12V 5RD12V STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) ±10 % ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: David Green CHECKED: T. Yin DATE: 02/01/05 DATE: 02/01/05 FAX: (949) 951-3974 T-1 ¾ (5mm) PANEL MOUNT ASSEMBLY, 12V REVISION: PART NO: PM5XX12VWX.X CAGE CODE : 32559 A SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
PM5GD12VW6 价格&库存
很抱歉,暂时无法提供与“PM5GD12VW6”相匹配的价格&库存,您可以联系我们找货
