PUNCH UNT-9/16" (POP)
Slug-Buster Knockout Punches 0.492 to 2.520
Cat No:
12357
UPC No:
783310123576
Description
"The contractor's choice - worldwide
Unique punch profile also splits slugs for easier slug removal
Use with battery-powered, hydraulic, ratchet or manual drivers
Uses standard Greenlee dies and draw studs
Slug Buster punches available in sizes up thru 2.52"" (64.0 mm)
U.S.Patent #4,543,722 for Slug-Buster "
Specifications
Application : For Punch Mild Steel, Aluminum, Fiberglass And Plastic
Capacity Mild Steel : 16 GA (1.500 MM)
Includes : Punch, Die And Draw Stud
Operation Type : Battery, Hydraulic, Ratchet or Manual Drivers
Replacement Part : 12357 UPC 12357 Punch, 12361 UPC 12361 Die And 1675AV UPC 04218
Draw Stud
Size : 9/16 IN (14.300 MM)
Sub Brand : Slug-Buster
Type : Knockout
Weight : 0.160 LB (73.500 GM)
很抱歉,暂时无法提供与“19712357”相匹配的价格&库存,您可以联系我们找货
