2191QU7-6V
2191QU7-6V
    VCC
    LED IND LIGHT 6V YELLOW
2191QU7-6V 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 2191QU Series Non-Relampable LED Solid-State Indicator Lights Description and Features All dimensions in inches. .380 Solid-state indicator lights complete with built-in currentlimiting resistor and rectifier diode. Mounting: Ø.310 MIN., supplied with push-on speednut SN1287. .090 .280 Terminals: Quick-connect, tinned brass .187 x .020 Lens: Polycarbonate Anode(+): Marked above terminal 1.310 Bezel: Polished stainless steel. Ø.310 MAX. Housing: White Nylon .690 Lens C olor R ed G reen Y ellow Internal R es is tor (ohms ) .187 T E R MINALS LE D S olid S tate Indicator Model No. Model No. (12V ) (24V ) 2191QU 1 -12V 2191QU 1 -24V 2191QU 5 -12V 2191QU 5 -24V 2191QU 7 -12V 2191QU 7-24V 390 1000 V oltage T able Nominal V AC 12V 24V 10 to 20 22 to 32 V DC 6 t o 13.5 12 to 24 Lens C olor Incorporates LE D* R ed 4304H1 G reen 4304H5 Y ellow 4304H7 * Also incorporates 1N4004 (400 P.I.V.) rectifier diode. To use 24V model: Beyond 32VAC add 30 ohms per volt; beyond 24 VDC add 50 ohms per volt. Use 1/2W resistor up to 50V; 1W resistor for 50V to 70V; 2W resistor for 75V to 125V. Do not use beyond 125V. CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
2191QU7-6V 价格&库存
很抱歉,暂时无法提供与“2191QU7-6V”相匹配的价格&库存,您可以联系我们找货
