2191UX1-24V
2191UX1-24V
    VCC
    LED IND LIGHT 24V RED
2191UX1-24V 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 2191U Series Non-Relampable LED Solid-State Indicator Lights Description and Features Solid-state indicator lights complete with built-in currentlimiting resistor and rectifier diode. .380 .280 Mounting: Ø.310 MIN., supplied with push-on speednut SN1287. .090 Wire Leads: No. 22 AWG (105°C) 4.40/4.80 long, stripped .430/.570 Lens: Polycarbonate Anode(+): Red lead 1.310 Bezel: Polished stainless steel. Ø.310 MAX. Housing: White Nylon All dimensions in inches. Lens C olor R ed G reen Y ellow Internal R es is tor (ohms ) Model No. (6V ) 2191U 1-6V 2191U 5-6V - LE D S olid S tate Indicator Model No. (12V ) 2191U 1-12V 2191U 5-12V 2191U 7-12V 150 390 V oltage T able Nominal V AC 6V 12V 24V 5 to 11 10 to 20 22 to 32 V DC 3.5 to 6.5 6 to 13.5 12 to 24 Model No. (24V ) 2191U 1-24V 2191U 5-24V 2191U 7-24V 1000 Lens C olor Incorporates LE D* R ed 4304H1 G reen 4304H5 Y ellow 4304H7 * Also incorporates 1N4004 (400 P.I.V.) rectifier diode. To use 24V model: Beyond 32VAC add 30 ohms per volt; beyond 24 VDC add 50 ohms per volt. Use 1/2W resistor up to 50V; 1W resistor for 50V to 70V; 2W resistor for 75V to 125V. Do not use beyond 125V. CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
2191UX1-24V 价格&库存
很抱歉,暂时无法提供与“2191UX1-24V”相匹配的价格&库存,您可以联系我们找货
