CNX722N90012W
CNX722N90012W
    VCC
    22MM WHITE 12V WIRES
CNX722N90012W 数据手册
22mm TuffLED™ Panel Mount Indicator Ruggedized CNX 722 Series with built-in LED offers fast, easy installation in harsh environments Applications • • • • • control cabinets instrument panels disinfection and sterilization environments transportation dashboards switch stations • • • • • safety applications outdoor signage aircraft and military industrial machinery vending and gaming machines • • • • • • wide angle viewable resistant to shock and vibration custom LEDs and lens colors available optional bezel available in many colors moisture sealed, IP 67/NEMA 6P rated RoHS compliant Key features • designed for extreme harsh and outdoor environments • variety of connection options for fast, easy installation • built-in LED can be used with 5, 12 or 24 volt D/C circuits • fast pitch threads ease assembly, requiring only1 turn or with 1” hextool • special nut assembles by • direct sunlight visibility Product dimensions 1.06 in[26.9mm] o 1.01 in[25.6mm] .86 in[21.9mm] Indicator Assemblies .81 in[20.6mm] o 1.26 in[32mm] .50 in[12.8mm] .47 in[11.8mm] 6 in[152.4mm] .12 in[3mm] Bezels o 1.26 in[32mm] engineered to light up your design www.vcclite.com 1.800.522.5546 Product specifications LED color** red green white blue yellow body retaining nut wire moisture seal bezel- plastic bezel- metal LED output typ intensity, mcd 1300-1900 700-1400 1300-1700 200-280 80-200 Installation specification mounting hole .855-.910” (21.7-23.1mm) panel Up to .300” (7.6mm) thickness Operating parameters operating -40°F (-40°C) to temperature 176°F (80°C) current 20mA Materials polycarbonate, UL 94-V2 PBT/glass filled, UL 94-V0 22 AWG 1007/1569 EPDM ABS, UL 94-HB aluminum alloy Ordering data CNX 722 22mm indicator ordering code (example) Body Type X= material C colored* N clear *Body color to match LED color CNX 722 X X00 XX X LED Color X00= color 200 red 400 yellow 500 green 600 blue 900 white Voltage input XX= voltage 05 5VDC 12 12VDC 24 24VDC Bezel Color *Optional bezel: BZL 722-X Bezel size = 22mm *Sold Separately engineered to light up your design Termination Style X= termination style B screw block quick disconnect/ T terminals W wire leads www.vcclite.com X= 0 2 4 5 6 9 A B C color black red yellow green blue white actual aluminum brushed aluminum chrome 1.800.522.5546
CNX722N90012W
物料型号:CNX 722 22mm指示器订购代码示例为CNX 722 X X00 XX X X00XXX,其中X代表不同的配置选项。
器件简介:CNX 722系列是一款坚固的面板安装指示器,内置LED,适用于恶劣环境的快速简易安装。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - LED输出:不同颜色的LED具有不同的典型强度,例如红色为1300-1900 mcd,绿色为700-1400 mcd。 - 安装规格:安装孔径为.855-.910英寸(21.7-23.1mm),面板厚度可达.300英寸(7.6mm)。 - 工作参数:工作温度范围为-40°F(-40°C)至176°F(80°C),工作电流为20mA。
功能详解:该指示器设计用于极端恶劣和户外环境,具有宽视角可视性、多种连接选项、抗冲击和振动、内置LED可与5、12或24伏直流电路配合使用。
应用信息:适用于控制柜、安全应用、仪表板、户外标志、消毒和灭菌环境、飞机和军事、运输仪表盘、工业机械、开关站以及自动售货机和游戏机。
封装信息:产品尺寸包括指示器组件和边框的尺寸,例如指示器组件的直径为1.01英寸(25.6mm)。
CNX722N90012W 价格&库存
很抱歉,暂时无法提供与“CNX722N90012W”相匹配的价格&库存,您可以联系我们找货
