SIT8924AM-72-33N-100.000000E 数据手册
SiT8924
Automotive AEC-Q100 Oscillator
The Smart Timing Choice
Features
Applications
AEC-Q100 with extended temperature range (-55°C to 125°C)
Automotive, extreme temperature and other high-rel electronics
Frequencies between 1 MHz and 110 MHz accurate to 6 decimal
places
Infotainment systems, collision detection devices, and in-vehicle
networking
Supply voltage of 1.8V or 2.25V to 3.63V
Power train control
Excellent total frequency stability as low as ±25 ppm
Industry best G-sensitivity of 0.1 PPB/G
Low power consumption of 3.8 mA typical at 1.8V
LVCMOS/LVTTL compatible output
Industry-standard packages: 2.0 x 1.6, 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2,
7.0 x 5.0 mm x mm
RoHS and REACH compliant, Pb-free, Halogen-free and
Antimony-free
Electrical Specifications
Table 1. Electrical Characteristics[1, 2]
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Frequency Range
Output Frequency Range
f
1
110
MHz
Refer to Table 13 and Table 14 for a list supported frequencies
Frequency Stability and Aging
Frequency Stability
F_stab
-25
+25
ppm
-30
+30
ppm
+50
ppm
-50
Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C, and
variations over operating temperature, rated power supply
voltage and load (15 pF ± 10%).
Operating Temperature Range
(ambient)
T_use
-40
+105
°C
-40
+125
°C
Extended Industrial, AEC-Q100 Grade 2
Automotive, AEC-Q100 Grade 1
-55
+125
°C
Extended Temperature, AEC-Q100
Supply Voltage and Current Consumption
Supply Voltage
Current Consumption
Vdd
Idd
1.62
1.8
1.98
V
2.25
3.63
V
All voltages between 2.25V and 3.63V including 2.5V, 2.8V, 3.0V
and 3.3V are supported.
4.0
4.8
mA
No load condition, f = 20 MHz, Vdd = 2.25V to 3.63V
3.8
4.5
mA
No load condition, f = 20 MHz, Vdd = 1.8V
LVCMOS Output Characteristics
Duty Cycle
Rise/Fall Time
DC
45
55
Tr, Tf
1.5
3
ns
All Vdds
Vdd = 2.25V - 3.63V, 20% - 80%
1.3
2.5
ns
Vdd = 1.8V, 20% - 80%
Output High Voltage
VOH
90%
Vdd
IOH = -4 mA (Vdd = 3.0V or 3.3V)
IOH = -3 mA (Vdd = 2.8V and Vdd = 2.5V)
IOH = -2 mA (Vdd = 1.8V)
Output Low Voltage
VOL
10%
Vdd
IOL = 4 mA (Vdd = 3.0V or 3.3V)
IOL = 3 mA (Vdd = 2.8V and Vdd = 2.5V)
IOL = 2 mA (Vdd = 1.8V)
Input High Voltage
VIH
70%
Vdd
Pin 1, OE
Input Low Voltage
VIL
30%
Vdd
Pin 1, OE
Input Pull-up Impedence
Z_in
100
k
Pin 1, OE logic high or logic low
Input Characteristics
Startup and Resume Timing
Startup Time
T_start
10
ms
Measured from the time Vdd reaches 90% of final value
Enable/Disable Time
T_oe
130
ns
f = 110 MHz. For other frequencies, T_oe = 100 ns + 3 * cycles
RMS Period Jitter
T_jitt
1.6
2.5
ps
f = 75 MHz, 2.25V to 3.63V
1.9
3.0
ps
f = 75 MHz, 1.8V
Jitter
RMS Phase Jitter (random)
T_phj
0.5
ps
f = 75 MHz, Integration bandwidth = 900 kHz to 7.5 MHz
1.3
ps
f = 75 MHz, Integration bandwidth = 12 kHz to 20 MHz
Notes:
1. All electrical specifications in the above table are specified with 15 pF output load and for all Vdd(s) unless otherwise stated.
2. The typical value of any parameter in the Electrical Characteristics table is specified for the nominal value of the highest voltage option for that parameter and
at 25 °C temperature.
SiTime Corporation
Rev. 1.01
990 Almanor Avenue, Sunnyvale, CA 94085
(408) 328-4400
www.sitime.com
Revised June 18, 2015
SiT8924
Table 2. Pin Description
Pin
Top View
Symbol
Functionality
Output Enable
1
OE/NC
No Connect
H[3]: specified frequency output
L: output is high impedance. Only output driver is disabled.
OE/NC
1
4
VDD
GND
2
3
OUT
[3]
Any voltage between 0 and Vdd or Open : Specified frequency
output. Pin 1 has no function.
2
GND
Power
Electrical ground[4]
3
OUT
Output
Oscillator output
4
VDD
Power
Power supply voltage[4]
Figure 1. Pin Assignments
Notes:
3. In OE mode, a pull-up resistor of 10k or less is recommended if pin 1 is not externally driven.
If pin 1 needs to be left floating, use the NC option.
4. A capacitor of value 0.1 µF or higher between Vdd and GND is required.
N
Table 3. Absolute Maximum Limits
Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the
IC is only guaranteed within the operational specifications, not at absolute maximum ratings.
Min.
Max.
Unit
Storage Temperature
Parameter
-65
150
°C
Vdd
-0.5
4
V
Electrostatic Discharge
2000
V
Soldering Temperature (follow standard Pb free soldering guidelines)
260
°C
Junction Temperature[5]
150
°C
Note:
5.Exceeding this temperature for extended period of time may damage the device.
Table 4. Thermal Consideration[6]
JA, 4 Layer Board
JA, 2 Layer Board
JC, Bottom
7050
142
273
30
5032
97
199
24
3225
109
212
27
2520
117
222
26
2016
152
252
36
(°C/W)
Package
(°C/W)
(°C/W)
Note:
6. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table.
Table 5. Maximum Operating Junction Temperature[7]
Max Operating Temperature (ambient)
105°C
115°C
125°C
135°C
Note:
7. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature.
Table 6. Environmental Compliance
Parameter
Condition/Test Method
Mechanical Shock
MIL-STD-883F, Method 2002
Mechanical Vibration
MIL-STD-883F, Method 2007
Temperature Cycle
JESD22, Method A104
Solderability
MIL-STD-883F, Method 2003
Moisture Sensitivity Level
MSL1 @ 260°C
Rev. 1.01
Page 2 of 12
www.sitime.com
SiT8924
Test Circuit and Waveform[8]
Vdd
Vout
0.1µF
tr
3
4
Power
Supply
Test
Point
1
tf
80% Vdd
15pF
(including probe
and fixture
capacitance)
2
50%
20% Vdd
High Pulse
(TH)
Low Pulse
(TL)
Period
Vdd
1k
OE/NC Function
Figure 2. Test Circuit
Figure 3. Waveform
Note:
8. Duty Cycle is computed as Duty Cycle = TH/Period.
Timing Diagrams
u
90% Vdd
Vdd
Vdd
50% Vdd
T_start
Pin 4 Voltage
[9]
No Glitch
during start up
OE Voltage
T_oe
CLK Output
CLK Output
HZ
HZ
T_start: Time to start from power-off
T_oe: Time to re-enable the clock output
Figure 4. Startup Timing (OE Mode)
Figure 5. OE Enable Timing (OE Mode Only)
Vdd
OE Voltage
50% Vdd
T_oe
CLK Output
HZ
T_oe: Time to put the output in High Z mode
Figure 6. OE Disable Timing (OE Mode Only)
Note:
9 SiT8924 has “no runt” pulses and “no glitch” output during startup or resume.
Rev. 1.01
Page 3 of 12
www.sitime.com
SiT8924
Performance Plots[10]
1.8 V
2.5 V
2.8 V
3V
DUT 1
DUT 2
DUT 3
DUT 4
DUT 5
DUT 6
DUT 7
DUT 8
DUT 9
DUT 10
25
3.3 V
15
Frequency (ppm)
Idd (mA)
5.5
5.0
4.5
4.0
10
m 5
p
p
y 0
c
n
e
u
q
re ‐5
F
‐10
‐15
3.5
‐20
3.0
60
80
100
‐25
‐55
Frequency (MHz)
2.5 V
2.8 V
‐15
5
25
45
65
85
105
125
Tem p er atur e(°C)
( C)
Temperature
Figure 7. Idd vs Frequency
1.8 V
‐35
3.0 V
Figure 8. Frequency vs Temperature
1.8 V
3.3 V
2.5 V
2.8 V
3.0 V
3.3 V
55
4.0
53
3.0
Duty cycle (%)
RMS period jitter (ps)
54
3.5
2.5
2.0
1.5
1.0
52
51
50
49
48
47
0.5
46
0.0
60
80
45
100
Frequency (MHz)
Figure 9. RMS Period Jitter vs Frequency
2.5 V
2.8 V
3.0 V
1.8 V
3.3 V
2.5
2.5
2.0
2.0
1.5
1.0
100
2.5 V
2.8 V
3.0 V
3.3 V
1.5
1.0
0.5
0.5
0.0
0.0
-55
-35
-15
5
25
45
65
85
105
125
Temperature (°C)
-55
-35
-15
5
25
45
65
85
105
125
Temperature (°C)
Figure 11. 20%-80% Rise Time vs Temperature
Rev. 1.01
80
Figure 10. Duty Cycle vs Frequency
Fall time (ns)
Rise time (ns)
1.8 V
60
Frequency (MHz)
Figure 12. 20%-80% Fall Time vs Temperature
Page 4 of 12
www.sitime.com
SiT8924
2.5 V
2.8 V
3.0 V
3.3 V
1.8 V
2.5 V
2.8 V
3.0 V
3.3 V
1
0.9
0.8
IPJ (ps)
IPJ (ps)
1.8 V
2
1.9
1.8
1.7
)s 1.6
(p
J 1.5
P
I 1.4
1.3
1.2
1.1
1
)s 0.7
p
(J
P
I 0.6
0.5
0.4
0.3
10
30
50
70
90
110
10
Frequency (MHz)
Frequency (MHz)
30
50
70
90
110
Frequency (MHz)
Frequency (MHz)
Figure 13. RMS Integrated Phase Jitter Random
(12 kHz to 20 MHz) vs Frequency[11]
Figure 14. RMS Integrated Phase Jitter Random
(900 kHz to 7.5 MHz) vs Frequency[11]
Notes:
10. All plots are measured with 15 pF load at room temperature, unless otherwise stated.
11. Phase noise plots are measured with Agilent E5052B signal source analyzer. Integration range is up to 5 MHz for carrier frequencies up to 40 MHz.
Rev. 1.01
Page 5 of 12
www.sitime.com
SiT8924
Programmable Drive Strength
The SiT8924 includes a programmable drive strength feature
to provide a simple, flexible tool to optimize the clock rise/fall
time for specific applications. Benefits from the programmable
drive strength feature are:
The SiT8924 can support up to 60 pF in maximum capacitive
loads with drive strength settings. Refer to the Rise/Tall Time
Tables (Table 7 to 11) to determine the proper drive strength
for the desired combination of output load vs. rise/fall time
SiT8924 Drive Strength Selection
• Improves system radiated electromagnetic interference
(EMI) by slowing down the clock rise/fall time.
• Improves the downstream clock receiver’s (RX) jitter by decreasing (speeding up) the clock rise/fall time.
• Ability to drive large capacitive loads while maintaining full
swing with sharp edge rates.
For more detailed information about rise/fall time control and
drive strength selection, see the SiTime Application Notes
section: http://www.sitime.com/support/application-notes.
Tables 7 through 11 define the rise/fall time for a given capacitive load and supply voltage.
EMI Reduction by Slowing Rise/Fall Time
Figure 15 shows the harmonic power reduction as the rise/fall
times are increased (slowed down). The rise/fall times are
expressed as a ratio of the clock period. For the ratio of 0.05,
the signal is very close to a square wave. For the ratio of 0.45,
the rise/fall times are very close to near-triangular waveform.
These results, for example, show that the 11th clock harmonic
can be reduced by 35 dB if the rise/fall edge is increased from
5% of the period to 45% of the period.
4. The left-most column represents the part number code for
the corresponding drive strength.
2. Select the capacitive load column that matches the application requirement (5 pF to 60 pF)
3. Under the capacitive load column, select the desired
rise/fall times.
5. Add the drive strength code to the part number for ordering
purposes.
Calculating Maximum Frequency
Based on the rise and fall time data given in Tables 7 through
11, the maximum frequency the oscillator can operate with
guaranteed full swing of the output voltage over temperature
can be calculated as follows:
trise=0.05
trise=0.1
trise=0.15
trise=0.2
10
Harmonic amplitude (dB)
1. Select the table that matches the SiT8924 nominal supply
voltage (1.8V, 2.5V, 2.8V, 3.0V, 3.3V).
M a x F re q u e n c y =
trise=0.25
trise=0.3
trise=0.35
trise=0.4
trise=0.45
-10
-20
where Trf_20/80 is the typical value for 20%-80% rise/fall
time.
-30
Example 1
-40
-50
Calculate fMAX for the following condition:
-60
-70
-80
1
5 x T rf_ 2 0 /8 0
1
3
5
7
9
11
Harm onic num ber
Figure 15. Harmonic EMI reduction as a Function of
Slower Rise/Fall Time
Jitter Reduction with Faster Rise/Fall Time
Power supply noise can be a source of jitter for the
downstream chipset. One way to reduce this jitter is to speed
up the rise/fall time of the input clock. Some chipsets may also
require faster rise/fall time in order to reduce their sensitivity to
this type of jitter. Refer to the Rise/Fall Time Tables (Table 7 to
Table 11) to determine the proper drive strength.
• Vdd = 1.8V (Table 7)
• Capacitive Load: 30 pF
• Desired Tr/f time = 3 ns (rise/fall time part number code = E)
Part number for the above example:
SiT8924AIE12-18E-66.666660
Drive strength code is inserted here. Default setting is “-”
High Output Load Capability
The rise/fall time of the input clock varies as a function of the
actual capacitive load the clock drives. At any given drive
strength, the rise/fall time becomes slower as the output load
increases. As an example, for a 3.3V SiT8924 device with
default drive strength setting, the typical rise/fall time is 1ns for
15 pF output load. The typical rise/fall time slows down to
2.6 ns when the output load increases to 45 pF. One can
choose to speed up the rise/fall time to 1.83 ns by then
increasing the drive strength setting on the SiT8924.
Rev. 1.01
Page 6 of 12
www.sitime.com
SiT8924
Rise/Fall Time (20% to 80%) vs CLOAD Tables
Table 7. Vdd = 1.8V Rise/Fall Times for Specific CLOAD
Table 8. Vdd = 2.5V Rise/Fall Times for Specific CLOAD
Rise/Fall Time Typ (ns)
Drive Strength \ CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
5 pF
15 pF
30 pF
45 pF
60 pF
L
A
R
B
T
E
U
F or "‐": default
6.16
3.19
2.11
1.65
0.93
0.78
0.70
0.65
11.61
6.35
4.31
3.23
1.91
1.66
1.48
1.30
22.00
11.00
7.65
5.79
3.32
2.94
2.64
2.40
31.27
16.01
10.77
8.18
4.66
4.09
3.68
3.35
39.91
21.52
14.47
11.08
6.48
5.74
5.09
4.56
L
A
R
B
T
E or "‐": default
U
F
4.13
2.11
1.45
1.09
0.62
8.25
4.27
2.81
2.20
1.28
12.82
7.64
5.16
3.88
2.27
21.45
11.20
7.65
5.86
3.51
27.79
14.49
9.88
7.57
4.45
0.54
0.43
0.34
1.00
0.96
0.88
2.01
1.81
1.64
3.10
2.79
2.54
4.01
3.65
3.32
Table 9. Vdd = 2.8V Rise/Fall Times for Specific CLOAD
Table 10. Vdd = 3.0V Rise/Fall Times for Specific CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
5 pF
15 pF
30 pF
45 pF
60 pF
L
A
R
B
T
3.77
1.94
1.29
0.97
0.55
7.54
3.90
2.57
2.00
1.12
12.28
7.03
4.72
3.54
2.08
19.57
10.24
7.01
5.43
3.22
25.27
13.34
9.06
6.93
4.08
E or "‐": default
U
F
0.44
0.34
0.29
1.00
0.88
0.81
1.83
1.64
1.48
2.82
2.52
2.29
3.67
3.30
2.99
L
A
R
B
T or "‐": default
E
U
F
3.60
1.84
1.22
0.89
0.51
0.38
0.30
0.27
7.21
3.71
2.46
1.92
1.00
0.92
0.83
0.76
11.97
6.72
4.54
3.39
1.97
1.72
1.55
1.39
18.74
9.86
6.76
5.20
3.07
2.71
2.40
2.16
24.30
12.68
8.62
6.64
3.90
3.51
3.13
2.85
Table 11. Vdd = 3.3V Rise/Fall Times for Specific CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
L
A
R
B
3.39
1.74
1.16
0.81
6.88
3.50
2.33
1.82
11.63
6.38
4.29
3.22
17.56
8.98
6.04
4.52
23.59
12.19
8.34
6.33
T or "‐": default
E
U
F
0.46
0.33
0.28
0.25
1.00
0.87
0.79
0.72
1.86
1.64
1.46
1.31
2.60
2.30
2.05
1.83
3.84
3.35
2.93
2.61
Rev. 1.01
Page 7 of 12
www.sitime.com
SiT8924
Pin 1 Configuration Options (OE or NC)
Pin 1 of the SiT8924 can be factory-programmed to support
two modes: Output Enable (OE) or No Connect (NC).
is enabled as shown in the waveform captures in Figure 16
and Figure 17.
Output Enable (OE) Mode
In the OE mode, applying logic low to the OE pin only disables
the output driver and puts it in Hi-Z mode. The core of the
device continues to operate normally. Power consumption is
reduced due to the inactivity of the output. When the OE pin is
pulled High, the output is typically enabled in
