FR40MR05
FR40MR05
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
    DIODE GEN PURP REV 1KV 40A DO5
FR40MR05 数据手册
FR40K05 thru FR40MR05 Silicon Fast Recovery Diode VRRM = 800 V - 1000 V IF = 40 A Features • High Surge Capability • Types from 800 V to 1000 V VRRM DO-5 Package • Not ESD Sensitive A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. 3. Stud is base. C A C Stud Stud (R) Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage FR40K(R)05 FR40M(R)05 Unit VRRM 800 1000 V VRMS 560 700 V VDC 800 1000 V Symbol Conditions Continuous forward current IF TC ≤ 100 °C 40 40 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 500 500 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol Conditions FR40K(R)05 FR40M(R)05 Unit VF IF = 40 A, Tj = 25 °C VR = 100 V, Tj = 25 °C VR = 100 V, Tj = 125 °C 1.0 25 10 1.0 25 10 μA mA IF=0.5 A, IR=1.0 A, IRR= 0.25 A 500 500 nS 0.8 0.8 °C/W IR V Recovery Time Maximum reverse recovery time TRR Thermal characteristics Thermal resistance, junction - case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/fr40mr05.pdf 1 FR40K05 thru FR40MR05 Oct. 2018 http://www.diodemodule.com/silicon_products/studs/fr40mr05.pdf 2 FR40K05 thru FR40MR05 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Min Millimeters Max Max 1/4 –28 UNF A Oct. 2018 Min B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 http://www.diodemodule.com/silicon_products/studs/fr40mr05.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: FR40MR05
FR40MR05
物料型号:FR40K05至FR40MR05
器件简介:这些是硅快速恢复二极管,具有高浪涌能力,不敏感于静电放电,提供800V至1000V的VRRM电压等级。
引脚分配:标准极性下,螺柱是阴极;反极性(R)下,螺柱是阳极。螺柱是基座。
参数特性: - 重复峰值反向电压:FR40K(R)05为800V,FR40M(R)05为1000V。 - 额定正向电流:在100°C时,两种型号均为40A。 - 正向电压:在40A电流和25°C时,两种型号均为1.0V。 - 反向电流:在100V和25°C时,两种型号均为25μA,125°C时为10mA。 - 最大反向恢复时间:在0.5A电流和1.0A存储电荷下,两种型号均为500纳秒。 - 热阻:结到壳体的热阻,两种型号均为0.8°C/W。
功能详解:文档提供了正向特性、正向浪涌电流、正向降额曲线和反向特性的图表。
应用信息:文档未明确提供应用信息,但这类二极管通常用于高功率电路中,如电源整流、电机驱动等。
封装信息:该产品采用DO-5封装(DO-203AB),并提供了详细的尺寸和端子配置。
FR40MR05 价格&库存
很抱歉,暂时无法提供与“FR40MR05”相匹配的价格&库存,您可以联系我们找货
FR40MR05
    • 1+217.65240
    • 200+86.84280
    • 500+83.94840
    • 1000+82.51200
    FR40MR05
    • 1+178.081011+22.32979
    • 10+127.6420310+16.00519
    • 100+101.04412100+12.67005
    库存:151
