1A7TA
1A7TA
    SMCDIODESOLUTIONS(桑德斯)
    R-1
    DIODEGENPURP1KV1AR-1
1A7TA 数据手册
1A1 THRU 1A7 1.0A MINIATURE SILICON RECTIFIER Technical Data Data Sheet N0542, Rev.- 1A1 THRU 1A7 1.0A MINIATURE SILICON RECTIFIER Features:         Green Products Diffused Junction Low Forward Voltage Drop High Current Capability High Reliability High Surge Current Capability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical data:     Case: Molded Plastic Terminals: Plated Leads Solderable Per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.181 grams(Approx) Mechanical Dimensions: In mm/Inches R-1  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1A1 THRU 1A7 1.0A MINIATURE SILICON RECTIFIER Green Products Technical Data Data Sheet N0542, Rev.- Marking Diagram Where XXXXX is YYWWL 1A1 = Part Name Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information Device 1A1-1A7 Package R-1 (Pb-Free) Shipping 5000pcs / Tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1A1 THRU 1A7 1.0A MINIATURE SILICON RECTIFIER Green Products Technical Data Data Sheet N0542, Rev.- Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Type Number Symbol Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR RMS Reverse Voltage VRMS 1A1 1A2 1A3 1A4 1A5 1A6 1A7 Unit 50 5 100 1 200 2 400 4 600 6 800 8 1000 1V 35 3 70 7 140 1 280 2 420 4 560 5 700 1 V Average forward rectified output current @TA = 75°C IO 1.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 30 A Forward Voltage @IF =1.0A VFM 1.0 V Peak Reverse Current At Rated DC Blocking Voltage @TA = 25°C @TA = 100°C IRM 5.0 50 µA Typical Junction Capacitance (Note 2) CJ 15 pF Typical Thermal Resistance Junction to Ambient (Note 1) RθJA 50 °C/W Operating Junction Temperature Range TJ -65 to +125 °C TSTG -65 to +150 °C Storage Temperature Range Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm form the case. 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1A1 THRU 1A7 1.0A MINIATURE SILICON RECTIFIER Technical Data Data Sheet N0542, Rev.-  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products 1A1 THRU 1A7 1.0A MINIATURE SILICON RECTIFIER Technical Data Data Sheet N0542, Rev.- Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
1A7TA 价格&库存
很抱歉,暂时无法提供与“1A7TA”相匹配的价格&库存,您可以联系我们找货
