IMPORTANT NOTICE
10 December 2015
1. Global joint venture starts operations as WeEn Semiconductors
Dear customer,
As from November 9th, 2015 NXP Semiconductors N.V. and Beijing JianGuang Asset
Management Co. Ltd established Bipolar Power joint venture (JV), WeEn Semiconductors, which
will be used in future Bipolar Power documents together with new contact details.
In this document where the previous NXP references remain, please use the new links as shown
below.
WWW - For www.nxp.com use www.ween-semi.com
Email - For salesaddresses@nxp.com use salesaddresses@ween-semi.com
For the copyright notice at the bottom of each page (or elsewhere in the document, depending
on the version) “© NXP Semiconductors N.V. {year}. All rights reserved” becomes “© WeEn
Semiconductors Co., Ltd. {year}. All rights reserved”
If you have any questions related to this document, please contact our nearest sales office via email or phone (details via salesaddresses@ween-semi.com).
Thank you for your cooperation and understanding,
WeEn Semiconductors
TO
-22
AC
BYW29E-150
Ultrafast power diode
17 September 2013
Product data sheet
1. General description
Ultrafast power diode in a SOD59 (2-lead TO-220AC) plastic package.
2. Features and benefits
Fast switching
Guaranteed ESD capability
High thermal cycling performance
Low on-state loss
Low thermal resistance
Rugged: reverse voltage surge capability
Soft recovery minimizes power-consuming oscillations
3. Applications
Output rectifiers in high-frequency switched-mode power supplies
4. Quick reference data
Table 1.
Symbol
Parameter
VRRM
repetitive peak reverse
voltage
IF(AV)
average forward
current
Conditions
Min
Typ
Max
Unit
150
V
8
A
IF = 8 A; Tj = 25 °C; Fig. 4
0.92
1.05
V
IF = 1 A; VR = 30 V; dIF/dt = 100 A/µs;
ns
8
kV
δ = 0.5 ; Tmb ≤ 128 °C; square-wave
pulse; Fig. 1; Fig. 2
Static characteristics
VF
forward voltage
Dynamic characteristics
trr
reverse recovery time
Tj = 25 °C; ramp recovery; Fig. 5; Fig. 7
Electrostatic discharge
VESD
electrostatic discharge
voltage
HBM; C = 250 pF; R = 1.5 kΩ
Scan or click this QR code to view the latest information for this product
BYW29E-150
NXP Semiconductors
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
K
Simplified outline
cathode
Graphic symbol
mb
K
A
001aaa020
2
A
anode
mb
mb
mounting base; cathode
1
2
TO-220AC (SOD59)
6. Ordering information
Table 3.
Type number
Package
BYW29E-150
Name
Description
Version
TO-220AC
plastic single-ended package; heatsink mounted; 1 mounting
hole; 2-lead TO-220AC
SOD59
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VRRM
Conditions
Min
Max
Unit
repetitive peak reverse voltage
150
V
VRWM
crest working reverse voltage
150
V
VR
reverse voltage
150
V
IF(AV)
average forward current
8
A
16
A
88
A
80
A
0.2
A
IFRM
repetitive peak forward current
δ = 0.5 ; tp = 25 µs; Tmb ≤ 128 °C;
square-wave pulse
IFSM
non-repetitive peak forward
current
tp = 8.3 ms; Tj(init) = 25 °C; sine-wave
pulse
tp = 10 ms; Tj(init) = 25 °C; sine-wave
pulse
IRRM
repetitive peak reverse current
BYW29E-150
Product data sheet
δ = 0.001 ; tp = 2 µs
All information provided in this document is subject to legal disclaimers.
17 September 2013
© NXP N.V. 2013. All rights reserved
2 / 10
BYW29E-150
NXP Semiconductors
Symbol
Parameter
Conditions
Min
Max
Unit
IRSM
non-repetitive peak reverse
current
tp = 100 µs
0.2
A
Tstg
storage temperature
-40
150
°C
Tj
junction temperature
150
°C
8
kV
VESD
electrostatic discharge voltage
003aaj507
12
δ=1
a = 1.57
Ptot
(W)
Ptot
(W)
1.9
2.2
6
0.5
8
003aaj508
8
2.8
0.2
4.0
4
0.1
4
2
Fig. 1.
8
IF(AV) (A)
Forward power dissipation as a function of
average forward current; square waveform;
maximum values
Fig. 2.
4
6
IF(AV) (A)
8
average forward current; sinusoidal waveform;
maximum values
8. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
Fig. 3
2.7
K/W
Rth(j-a)
thermal resistance
from junction to
ambient
in free air
60
K/W
BYW29E-150
Product data sheet
17 September 2013
3 / 10
BYW29E-150
NXP Semiconductors
003aaj513
10
Zth(j-mb)
(K/W)
1
10-1
P
δ=
10-2
tp
10-3
10-6
Fig. 3.
10-5
10-4
10-3
10-2
10-1
tp
T
t
T
1
10
tp (s)
Transient thermal impedance from junction to mounting base as a function of pulse width
9. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
0.92
1.05
V
IF = 20 A; Tj = 25 °C; Fig. 4
1.1
1.3
V
IF = 8 A; Tj = 150 °C; Fig. 4
0.8
0.895
V
VR = 150 V; Tj = 25 °C
2
10
µA
VR = 150 V; Tj = 100 °C
0.2
0.6
mA
IF = 2 A; VR = 30 V; dIF/dt = 20 A/µs;
4
11
nC
ns
15
ns
1
V
VF
IR
forward voltage
reverse current
Qr
recovered charge
Tj = 25 °C; Fig. 5; Fig. 6
trr
IF = 0.5 A; IR = 1 A; IR(meas) = 0.25 A;
Tj = 25 °C; step recovery; Fig. 8
VFRM
forward recovery
voltage
BYW29E-150
Product data sheet
IF = 1 A; dIF/dt = 10 A/µs; Tj = 25 °C;
Fig. 9
17 September 2013
4 / 10
BYW29E-150
NXP Semiconductors
003aaj509
30
dlF
IF
dt
IF
(A)
trr
time
(1)
(2)
25 %
(3)
10
IR
Fig. 4.
100 %
Qr
IRM
003aac562
1
1.5
VF (V)
2
Fig. 5.
Reverse recovery definitions; ramp recovery
Forward current as a function of forward
voltage
003aaj510
103
003aaj511
103
Qr
(nC)
trr
(ns)
102
(2)
102
(4)
(3)
(2)
(1)
(1)
10
1
Fig. 6.
10
1
10
dIF
1
102
Recovered charge as a function of rate of
change of forward current; maximum values
BYW29E-150
Product data sheet
Fig. 7.
1
dIF
102
Reverse recovery time as a function of rate of
17 September 2013
10
5 / 10
BYW29E-150
NXP Semiconductors
IF
IF
IF
trr
time
time
0.25 x IR
VF
Qr
VFRM
IR
IR
Fig. 8.
VF
003aac563
time
Reverse recovery definitions; step recovery
001aab912
Fig. 9.
BYW29E-150
Product data sheet
Forward recovery definitions
17 September 2013
6 / 10
BYW29E-150
NXP Semiconductors
10. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 2-lead TO-220AC
SOD59
E
A
A1
P
q
D1
D
H
Q
b1
L
1
2
c
b
e
Dimensions
Unit
mm
max
nom
min
10 mm
scale
A
A1
b
b1(1)
c
D
D1
E
e
4.7
1.40 0.95
1.7
0.65 15.8
6.8 10.30
4.3
1.15 0.70
1.3
0.45 15.6
6.4
9.65
H
5.08
(REF)
L
P
Q
q
16.25 15.0 3.80
2.6
2.9
15.70 12.5 3.65
2.2
2.7
Note
1. Protruded dambar are included in the dimension.
Outline
version
SOD59
sod059_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
09-08-25
12-11-27
2-lead TO-220AC
Fig. 10. Package outline TO-220AC (SOD59)
BYW29E-150
Product data sheet
17 September 2013
7 / 10
BYW29E-150
NXP Semiconductors
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
11. Legal information
11.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nxp.com.
11.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
NXP Semiconductors does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local NXP
Semiconductors sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
11.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, NXP Semiconductors does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. NXP Semiconductors takes no
responsibility for the content in this document if provided by an information
source outside of NXP Semiconductors.
BYW29E-150
Product data sheet
Right to make changes — NXP Semiconductors reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors and its suppliers accept no liability for
inclusion and/or use of NXP Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using NXP Semiconductors products, and NXP
Semiconductors accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the NXP Semiconductors product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
17 September 2013
8 / 10
BYW29E-150
NXP Semiconductors
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific NXP Semiconductors product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor
tested in accordance with automotive testing or application requirements.
NXP Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without NXP Semiconductors’ warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
NXP Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies NXP Semiconductors for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond NXP Semiconductors’
standard warranty and NXP Semiconductors’ product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
11.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV,
FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE,
ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse,
QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET,
TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V.
HD Radio and HD Radio logo — are trademarks of iBiquity Digital
Corporation.
BYW29E-150
Product data sheet
17 September 2013
9 / 10
BYW29E-150
NXP Semiconductors
12. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Limiting values .......................................................2
8
Thermal characteristics .........................................3
9
Characteristics ....................................................... 4
10
Package outline ..................................................... 7
11
11.1
11.2
11.3
11.4
Legal information ...................................................8
Data sheet status ................................................. 8
Definitions .............................................................8
Disclaimers ...........................................................8
Trademarks .......................................................... 9
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
Date of release: 17 September 2013
BYW29E-150
Product data sheet
17 September 2013
10 / 10
