BYC15-600,127
BYC15-600,127
    WEEN(瑞能)
    TO-220-2
    DIODE GEN PURP 500V 15A TO220AC
BYC15-600,127 数据手册
IMPORTANT NOTICE 10 December 2015 1. Global joint venture starts operations as WeEn Semiconductors Dear customer, As from November 9th, 2015 NXP Semiconductors N.V. and Beijing JianGuang Asset Management Co. Ltd established Bipolar Power joint venture (JV), WeEn Semiconductors, which will be used in future Bipolar Power documents together with new contact details. In this document where the previous NXP references remain, please use the new links as shown below. WWW - For www.nxp.com use www.ween-semi.com Email - For salesaddresses@nxp.com use salesaddresses@ween-semi.com For the copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) “© NXP Semiconductors N.V. {year}. All rights reserved” becomes “© WeEn Semiconductors Co., Ltd. {year}. All rights reserved” If you have any questions related to this document, please contact our nearest sales office via email or phone (details via salesaddresses@ween-semi.com). Thank you for your cooperation and understanding, WeEn Semiconductors BYC15-600 Hyperfast power diode Rev. 02 — 29 July 2010 Product data sheet 1. Product profile 1.1 General description Hyperfast power diode in a SOD59 (2-lead TO-220AC) plastic package 1.2 Features and benefits „ Extremely fast switching „ Low thermal resistance „ Low reverse recovery current „ Reduces switching loss in associated MOSFET 1.3 Applications „ Continuous Current Mode (CCM) Power „ Half-bridge or full-bridge switched-mode „ Half-bridge lighting ballasts 1.4 Quick reference data Table 1. Symbol Quick reference data Parameter Conditions Min Typ Max Unit Specify Name VRRM repetitive peak reverse voltage - - 600 V IF(AV) average forward current square-wave pulse; δ = 0.5 ; Tmb ≤ 98 °C; see Figure 1; see Figure 2 - - 15 A IF = 15 A; Tj = 150 °C; see Figure 3 - 1.4 2 V IF = 15 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 25 °C; see Figure 4 - 19 - ns Static characteristics VF forward voltage Dynamic characteristics trr reverse recovery time BYC15-600 NXP Semiconductors Hyperfast power diode 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 K cathode 2 A anode mb mb mounting base; cathode Graphic symbol K mb A 001aaa020 1 2 SOD59 (TO-220AC) 3. Ordering information Table 3. Ordering information Type number Package BYC15-600 Name Description Version TO-220AC plastic single-ended package; heatsink mounted; 1 mounting hole; 2-lead TO-220AC SOD59 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Specify Name VRRM repetitive peak reverse voltage - 600 V VRWM crest working reverse voltage - 600 V VR reverse voltage Tmb ≤ 100 °C; DC - 500 V IF(AV) average forward current square-wave pulse; δ = 0.5 ; Tmb ≤ 98 °C; see Figure 1; see Figure 2 - 15 A IFRM repetitive peak forward current square-wave pulse; δ = 0.5 ; tp = 25 µs; Tmb ≤ 98 °C - 30 A IFSM non-repetitive peak forward current tp = 10 ms; sine-wave pulse; Tj(init) = 25 °C - 200 A tp = 8.3 ms; sine-wave pulse; Tj(init) = 25 °C - 220 A Tstg storage temperature -40 150 °C Tj junction temperature - 150 °C BYC15-600 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 29 July 2010 © NXP B.V. 2010. All rights reserved. 2 of 11 BYC15-600 NXP Semiconductors Hyperfast power diode 003aac083 40 Ptot (W) 003aac084 50 Ptot (W) a = 1.57 δ =1 40 1.9 30 0.5 2.2 2.8 30 0.2 4.0 20 0.1 20 10 10 0 0 0 5 10 IF(AV) (A) 0 15 6 12 18 IF(AV) (A) 24 a = form factor = IF(RMS) / IF(AV) Fig 1. Forward power dissipation as a function of average forward current; sinusoidal waveform; maximum values BYC15-600 Product data sheet Fig 2. Forward power dissipation as a function of average forward current; square waveform; maximum values All information provided in this document is subject to legal disclaimers. Rev. 02 — 29 July 2010 © NXP B.V. 2010. All rights reserved. 3 of 11 BYC15-600 NXP Semiconductors Hyperfast power diode 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Specify Name Rth(j-mb) thermal resistance from junction with heatsink compound to mounting base - - 1.5 K/W Rth(j-a) thermal resistance from junction in free air to ambient - 60 - K/W BYC15-600 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 29 July 2010 © NXP B.V. 2010. All rights reserved. 4 of 11 BYC15-600 NXP Semiconductors Hyperfast power diode 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit IF = 30 A; Tj = 150 °C; see Figure 3 - 1.7 2.3 V IF = 15 A; Tj = 25 °C; see Figure 3 - 1.9 2.9 V IF = 15 A; Tj = 150 °C; see Figure 3 - 1.4 2 V VR = 500 V; Tj = 100 °C - 1.1 3 mA VR = 600 V; Tj = 25 °C - 12 200 µA IF = 15 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 100 °C; see Figure 4 - 32 40 ns IF = 1 A; VR = 30 V; dIF/dt = 50 A/µs; Tj = 25 °C; see Figure 4 - 35 55 ns IF = 15 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 25 °C; see Figure 4 - 19 - ns IF = 15 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 125 °C; see Figure 4 - 9.5 12 A IF = 15 A; VR = 400 V; dIF/dt = 50 A/µs; Tj = 125 °C; see Figure 4 - 3 7.5 A IF = 15 A; dIF/dt = 100 A/µs; Tj = 25 °C; see Figure 5 - 8 11 V Static characteristics forward voltage VF reverse current IR Dynamic characteristics reverse recovery time trr peak reverse recovery current IRM VFR forward recovery voltage 003aac082 50 dlF IF IF (A) dt 40 trr 30 time 10 % 20 (1) (2) (3) Qr 100 % 10 IRM IR 001aab911 0 0 1 2 3 VF (V) 4 (1) Tj = 150 °C; typical values (2) Tj = 150 °C; maximum values (3) Tj = 25 °C; maximum values Fig 3. Forward current as a function of forward voltage BYC15-600 Product data sheet Fig 4. Forward recovery definitions All information provided in this document is subject to legal disclaimers. Rev. 02 — 29 July 2010 © NXP B.V. 2010. All rights reserved. 5 of 11 BYC15-600 NXP Semiconductors Hyperfast power diode IF time VF VFRM VF time 001aab912 Fig 5. Forward recovery definitions BYC15-600 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 29 July 2010 © NXP B.V. 2010. All rights reserved. 6 of 11 BYC15-600 NXP Semiconductors Hyperfast power diode 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 2-lead TO-220AC SOD59 E A A1 P q D1 D H Q b1 L 1 2 c b e 0 5 scale Dimensions Unit mm max nom min 10 mm A A1 b b1(1) c D D1 E 4.7 1.40 0.95 1.7 0.65 15.8 6.8 10.30 4.3 1.15 0.70 1.3 0.45 15.6 6.4 9.65 e H 5.08 (REF) P Q q 16.25 15.0 L 3.7 2.6 2.9 15.70 12.5 3.5 2.2 2.7 Note 1. Protruded dambar are included in the dimension. Outline version SOD59 Fig 6. sod059_po References IEC JEDEC JEITA European projection Issue date 09-08-17 09-08-25 2-lead TO-220AC Package outline SOD59 (TO-220AC) BYC15-600 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 29 July 2010 © NXP B.V. 2010. All rights reserved. 7 of 11 BYC15-600 NXP Semiconductors Hyperfast power diode 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BYC15-600 v.2 20100729 Product data sheet - BYC15-600 v.1 - - Modifications: BYC15-600 v.1 BYC15-600 Product data sheet • Various changes to content. 20071129 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 29 July 2010 © NXP B.V. 2010. All rights reserved. 8 of 11 BYC15-600 NXP Semiconductors Hyperfast power diode 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BYC15-600 Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the NXP Semiconductors product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. NXP Semiconductors does not accept any liability in this respect. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. All information provided in this document is subject to legal disclaimers. Rev. 02 — 29 July 2010 © NXP B.V. 2010. All rights reserved. 9 of 11 BYC15-600 NXP Semiconductors Hyperfast power diode Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse, QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. 10. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com BYC15-600 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 29 July 2010 © NXP B.V. 2010. All rights reserved. 10 of 11 BYC15-600 NXP Semiconductors Hyperfast power diode 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . .9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . .9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . .9 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .10 Contact information. . . . . . . . . . . . . . . . . . . . . .10 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2010. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 29 July 2010 Document identifier: BYC15-600
BYC15-600,127 价格&库存
很抱歉,暂时无法提供与“BYC15-600,127”相匹配的价格&库存,您可以联系我们找货
BYC15-600,127
  • 1+18.327661+2.37118
  • 10+11.7042210+1.51426
  • 100+7.91729100+1.02432
  • 500+6.29703500+0.81469
  • 1000+5.998861000+0.77612
库存:6241
