FR30GR02
FR30GR02
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
    Diode Standard, Reverse Polarity 400V 30A Chassis, Stud Mount DO-5
FR30GR02 数据手册
FR30A02 thru FR30JR02 Silicon Fast Recovery Diode VRRM = 50 V - 600 V IF = 30 A Features • High Surge Capability • Types from 50 V to 600 V VRRM DO-5 Package • Not ESD Sensitive C A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Symbol Conditions FR30A(R)02 FR30B(R)02 FR30D(R)02 FR30G(R)02 FR30J(R)02 Unit VRRM 50 VRMS VDC 100 200 400 600 V 35 70 140 280 420 V 50 100 200 400 600 V Continuous forward current IF TC ≤ 100 °C 30 30 30 30 30 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 300 300 300 300 300 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol Conditions VF IF = 30 A, Tj = 25 °C VR = 50 V, Tj = 25 °C VR = 50 V, Tj = 125 °C 1.0 25 10 1.0 25 10 1.0 25 10 1.0 25 10 1.0 25 10 μA mA IF=0.5 A, IR=1.0 A, IRR= 0.25 A 200 200 200 200 250 nS 0.46 0.46 0.46 0.46 0.46 °C/W IR FR30A(R)02 FR30B(R)02 FR30D(R)02 FR30G(R)02 FR30J(R)02 Unit V Recovery Time Maximum reverse recovery time TRR Thermal characteristics Thermal resistance, junction - case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/fr30gr02.pdf 1 FR30A02 thru FR30JR02 Oct. 2018 http://www.diodemodule.com/silicon_products/studs/fr30gr02.pdf 2 FR30A02 thru FR30JR02 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Min Millimeters Max Max 1/4 –28 UNF A Oct. 2018 Min B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 http://www.diodemodule.com/silicon_products/studs/fr30gr02.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: FR30GR02
FR30GR02 价格&库存
很抱歉,暂时无法提供与“FR30GR02”相匹配的价格&库存,您可以联系我们找货
