S300Y
S300Y
    GENESICSEMICONDUCTOR
    DO-205AB
S300Y 数据手册
S300Y thru S300ZR Silicon Standard Recovery Diode VRRM = 1600 V - 2000 V IF =300 A Features • High Surge Capability • Types from 1600 V to 2000 V VRRM DO-9 Package • Not ESD Sensitive Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. A C 3. Stud is base. A C Stud Stud (R) Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) S300Y (R) S300Z (R) Unit VRRM 1600 2000 V VRMS 1131 1414 V VDC 1600 2000 V Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Conditions Continuous forward current IF TC ≤ 130 °C 300 300 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 6850 6850 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Conditions S300Y (R) S300Z (R) Unit IF = 300 A, Tj = 25 °C VR = 1600 V, Tj = 25 °C VR = 1600 V, Tj = 175 °C 1.2 10 12 1.2 10 12 μA mA 0.16 0.16 °C/W Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol VF IR V Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/s300y.pdf 1 S300Y thru S300ZR Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s300y.pdf 2 S300Y thru S300ZR Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO-9 (DO--205AB) 9(DO205AB) H I F A C B D A C Stud Stud (R) G C E A Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s300y.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: S300Y
S300Y 价格&库存
很抱歉,暂时无法提供与“S300Y”相匹配的价格&库存,您可以联系我们找货
S300Y
  • 1+602.189771+77.90932
S300Y
    • 1+980.64000
    • 200+391.28400
    • 496+378.20520
    • 1000+371.74680
