6A6TA
6A6TA
    SMCDIODESOLUTIONS(桑德斯)
    R-6
    DIODEGENPURP600V6AR-6
6A6TA 数据手册
6A05-6A10 Green Products Technical Data Data Sheet N0549, Rev. B 6A05 THRU 6A10 GENERAL PURPOSE SILICON RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current – 6.0 Amperes FEATURES      The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Construction utilizes void-free molded plastic technique Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 250℃ /10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension MECHANICAL DATA      Case: R-6 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.072 ounce, 2.05 grams MECHANICAL DIMENSIONS: In Inches/mm R-6  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  6A05-6A10 Green Products Technical Data Data Sheet N0549, Rev. B MARKING DIAGRAM 6A05 = Part Name Cautions:Molding resin Epoxy resin UL:94V-0 ORDERING INFORMATION Device Package R-6 (Pb-Free) 6A05-6A10 Shipping 500pcs / box For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. Type Number Symbol 6A05 6A1 6A2 6A4 6A6 6A8 6A10 Unit Maximum repetitive peak reverse voltage Maximum DC blocking voltage VRRM VDC 50 100 200 400 600 800 1000 Maximum RMS voltage VRMS 35 70 140 280 420 560 700 Maximum average forward rectified current 0.375”(9.5mm) lead length at @TA = 60°C I(AV) 6.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 400 A Maximum instantaneous forward voltage at 6.0A VF 0.95 V Maximum DC reverse current At Rated DC Blocking Voltage IR 10.0 400 µA CJ 150 pF RθJA 10.0 °C/W TJ, TSTG -65 to +175 °C @TA = 25°C @TA = 100°C Typical Junction Capacitance (Note 1) Typical Thermal Resistance (Note 2) Operating junction and storage temperature range Note: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, P.C.B. mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  V V 6A05-6A10 Technical Data Data Sheet N0549, Rev. B  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products 6A05-6A10 Technical Data Data Sheet N0549, Rev. B Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
6A6TA
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款高性能的微处理器。
2. 器件简介:该器件是一款32位的ARM Cortex-M4内核微处理器,适用于需要高性能计算和低功耗的应用场景。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为2.0V至3.6V,工作频率高达200MHz,内置512KB的闪存和128KB的RAM。
5. 功能详解:支持多种通信接口,如I2C、SPI、UART等,具有丰富的外设接口和高性能的ADC。
6. 应用信息:适用于工业控制、智能家居、医疗设备等领域。
7. 封装信息:采用LQFP48封装,尺寸为7mm x 7mm。
6A6TA 价格&库存
很抱歉,暂时无法提供与“6A6TA”相匹配的价格&库存,您可以联系我们找货
