MBRF1060
MBRF1060
    SMCDIODESOLUTIONS(桑德斯)
    TO-220AC
    特性:150℃结温工作。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频工作。 保护环,增强耐用性和长期可靠性。 这是无铅器件。应用:开关电源。 转换器
MBRF1060 数据手册
MBRF1060 Technical Data Data Sheet N0821, Rev. A Green Products MBRF1060 SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • • 150 °C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 c D E e e1 H1 L L1 L2 L3 L4 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 ITO-220AC(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 1.10 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 1.50 3.70 3.39 2.90 MBRF1060 Technical Data Data Sheet N0821, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 10 60 SSG YY WW L = Device Type = Package type = Forward Current (10A) = Reverse Voltage (60V) = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AC (Pb-Free) MBRF1060 Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current(per leg) Symbol VRRM VRWM VR Condition - Max. Units V 60 IF (AV) 50% duty cycle @TC = 80°C, rectangular wave form 10 A IFSM 8.3 ms, half Sine pulse 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF1060 Technical Data Data Sheet N0821, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop* Reverse Current* Symbol VF1 VF2 IR1 IR2 Junction Capacitance Voltage Rate of Change * CT dv/dt Condition @ 10A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz - Typ. 0.66 0.61 0.009 Max. 0.80 0.70 1.0 Units V V mA 3 6 mA 260 400 pF - 10,000 V/μs Specification -55 to +150 -55 to +150 2.0 Units °C °C 0.50 °C/W 1.6 g Pulse Width < 300µs, Duty Cycle
MBRF1060 价格&库存
很抱歉,暂时无法提供与“MBRF1060”相匹配的价格&库存,您可以联系我们找货
