MURF860
MURF860
    SMCDIODESOLUTIONS(桑德斯)
    TO-220AC
MURF860 数据手册
MURF860 Green Products Technical Data Data Sheet N0344, Rev. A MURF860 ULTRAFAST RECTIFIER Applications:    Switching Power Supply Power Switching Circuits General Purpose Features:         Ultra-Fast Switching High Current Capability Low Reverse Leakage Current High Surge Current Capability Plastic Material has UL Flammability Classification 94V-O This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 c D E e e1 H1 L L1 L2 L3 L4 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 ITO-220AC(HD)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 1.10 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 1.50 3.70 3.39 2.90 MURF860 Green Products Technical Data Data Sheet N0344, Rev. A Marking Diagram: Where XXXXX is YYWWL MUR F 8 60 SSG YY WW L = Device Type = Package type = Forward Current (8A) = Reverse Voltage (600V) = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MURF860 Package ITO-220AC (Pb-Free) Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MURF860 Green Products Technical Data Data Sheet N0344, Rev. A Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Symbol MURF860 Unit Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR 600 V RMS Reverse Voltage VR(RMS) 420 V Average Rectified Output Current @TA = 55°C Io 8.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 110 A Forward Voltage (per element) VFM1 2.2 V VFM2 2.0 V @IF = 8.0A, TJ=25°C @IF = 8.0A, TJ=100°C Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 100°C Maximum Reverse Recovery Time (Note 1) IRM Trr 5 50 50 Max. Voltage Rate of Change dv/dt 10,000 Typical Thermal Resistance Junction to Ambient (Note 2) RθJA 25 Storage Temperature Range TSTG, TJ Approximate Weight wt Case Style -55 to +150 1.6 ITO-220AC Note: 1. Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 2. Mount on Cu-Pad Size 16mm×16mm on P.C.B.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  µA ns V/µs K/W °C g MURF860 Green Products Technical Data Data Sheet N0344, Rev. A 100 TJ=125℃ TJ=25℃ 10 TJ=25℃ 1 0 5 10 15 20 25 30 35 40 Re ve r s e V oltage -V R(V ) Fig.1-Typical Junction Capacitance Instantaneous Forward CurrentIF(A) Junction Capacitance-CT(PF) 1000 Fig.2-Typical Reverse Characteristics 100 10 TJ=25℃ 1 0.5 0.8 1.1 1.4 1.7 Forward Voltage Drop-VF(V) Fig.3-Typical Forward Voltage Drop Characteristics  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  2 MURF860 Technical Data Data Sheet N0344, Rev. A Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
MURF860 价格&库存
很抱歉,暂时无法提供与“MURF860”相匹配的价格&库存,您可以联系我们找货
