MBRF10200
MBRF10200
    SMCDIODESOLUTIONS(桑德斯)
    TO-220AC
    特性:150℃ TJ 工作。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频操作。 保护环,增强耐用性和长期可靠性。 这是无铅器件。应用:开关电源。 转换器
MBRF10200 数据手册
SANGDEST MICROELECTRONICS MBRF10200 Green Products Technical Data Data Sheet N0838, Rev. A MBRF10200 SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 c D E e e1 H1 L L1 L2 L3 L4 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 1.10 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 1.50 3.70 3.39 2.90 ITO-220AC(HD) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF10200 Green Products Technical Data Data Sheet N0838, Rev. A Marking Diagram: Where XXXXX is YYWWL MBR F 10 200 SSG YY WW L = Device Type = Package type = Forward Current (10A) = Reverse Voltage (200V) = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AC (Pb-Free) MBRF10200 Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRWM IF(AV) IFSM Condition 50% duty cycle @TC = 115°C, rectangular wave form Max. 100 10 Units V A 8.3 ms, half Sine pulse 128 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF10200 Green Products Technical Data Data Sheet N0838, Rev. A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg)* Max. Reverse Current (per leg)* Symbol VF1 VF2 IR1 IR2 Typical Series Inductance (per leg) Max. Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * LS dv/dt VISO Condition @ 10A, Pulse, TJ = 25 °C @ 10 A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Max. 0.95 0.85 1.0 Units V V mA 6 mA 8.0 nH 10,000 4500 V/µs V 3500 1500 Pulse Width < 300µs, Duty Cycle
MBRF10200 价格&库存
很抱歉,暂时无法提供与“MBRF10200”相匹配的价格&库存,您可以联系我们找货
