MBR1545
MBR1545
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-2
    特性:150℃ TJ 操作。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频操作。 保护环,增强耐用性和长期可靠性。 这是无铅器件。应用:开关电源。 转换器
MBR1545 数据手册
MBR1545 Technical Data Data Sheet N0130, Rev. B Green Products MBR1545 SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • 150 °C TJ operation Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions (In mm) Symbol A A1 A2 b b1 c D D1 E E1 e1 H1 L L1 ΦP Q Θ1 Θ2 Θ3 Dimensions in millimeters Min. Typical Max. 4.55 1.17 2.59 0.71 0.36 14.64 8.55 10.01 9.98 6.04 13.00 3.74 2.54 4.70 1.27 2.69 0.81 1.27 0.38 14.94 8.07 10.16 10.18 5.08 6.24 13.86 3.80 3.84 2.74 5° 4° 4° TO-220AC • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 4.85 1.37 2.89 0.96 0.61 15.24 8.85 10.31 10.38 6.44 14.08 4.04 2.94 MBR1545 Technical Data Data Sheet N0130, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR 15 45 SSG YY WW L = Device Type = Forward Current (15A) = Reverse Voltage (45V) = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR1545 Package Shipping TO-220AC(Pb-Free) 50pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current Symbol VRRM VRWM VR IF (AV) IFSM Condition - Max. 45 Units 50% duty cycle @TC =123 °C, rectangular wave form 8.3 ms, half Sine pulse 15 A 240 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR1545 Technical Data Data Sheet N0130, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop* Reverse Current * Symbol VF1 VF2 IR1 IR2 Junction Capacitance CT Typical Series Inductance LS Voltage Rate of Change * dv/dt Condition @ 15 A, Pulse, TJ = 25 °C @ 15 A, Pulse, TJ = 125 °C @VR = rated VR TC = 25 °C @VR = rated VR TC = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.60 0.57 Max. 0.70 0.60 Units V V 0.03 1.0 mA 15 40 mA 300 800 pF 8.0 - nH - 10,000 V/μs Specification -55 to +150 -55 to +150 1.6 Units °C °C °C/W 1.6 g Pulse Width < 300µs, Duty Cycle
MBR1545 价格&库存
很抱歉,暂时无法提供与“MBR1545”相匹配的价格&库存,您可以联系我们找货
