246NQ200-1
246NQ200-1
    SMCDIODESOLUTIONS(桑德斯)
    HALF-PAK
    电压:200V
246NQ200-1 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N0063, Rev. A 246NQ200-1 Green Products 246NQ200-1 SCHOTTKY RECTIFIER Applications: ● Switching power supply ● Converters ● Free-Wheeling diodes ● Reverse battery protection Features: • • • • • • • • • • • • 175 ℃ TJ operation Unique high power, Half-Pak module Low profile, high current package Replaces three parallel DO-5’S Easier to mount and lower profile than DO-5’S High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In Inches / mm PRM1-1(HALF PAK Module) MARKING,MOLDING RESIN st nd Marking for 246NQ200-1, 1 row SS YYWWL, 2 row 246NQ200-1 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 246NQ200-1 Technical Data Data Sheet N0063, Rev. A Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM IF(AV) IFSM Condition 50% duty cycle @TC =110°C, rectangular wave form 8.3 ms, half Sine pulse Max. 200 240 3950 Units V A A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * Symbol VF1 VF2 IR1 IR2 CT LS dv/dt Condition @ 240A, Pulse, TJ = 25 °C @ 240A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 1.12 0.79 6 85 3600 Units V V mA mA pF 6.0 nH 10,000 V/μs Specification -55 to +175 -55 to +175 Units °C °C Pulse Width < 300µs, Duty Cycle
246NQ200-1 价格&库存
很抱歉,暂时无法提供与“246NQ200-1”相匹配的价格&库存,您可以联系我们找货
246NQ200-1
  • 1+363.659261+47.04488
  • 27+244.3022527+31.60423
  • 108+225.20366108+29.13354
