PMEG6010AED,115
PMEG6010AED,115
    NEXPERIA(安世)
    SC74-6
    DIODE SCHOTTKY 60V 1A 6TSOP
PMEG6010AED,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET lfpage M3D302 PMEG6010AED Low VF (MEGA) Schottky barrier diode Product data sheet 2003 Jun 27 NXP Semiconductors Product data sheet Low VF (MEGA) Schottky barrier diode FEATURES PMEG6010AED PINNING • Low switching losses PIN DESCRIPTION • Very high surge current absorption capability 1 cathode • Fast recovery time 2 cathode • Guard ring protected 3 anode • Plastic SMD package. 4 anode 5 cathode 6 cathode APPLICATIONS • Low power switched-mode power supplies • Rectification • Polarity protection. handbook, halfpage 6 4 5 GENERAL DESCRIPTION Planar Schottky barrier diode encapsulated in a SOT457 (SC-74) small plastic package. 1, 2 5, 6 1 2 3, 4 3 MHC634 Marking code: M4. Fig.1 Simplified outline SOT457 (SC-74) and symbol. LIMITING VALUES In accordance with Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT − 60 V − 1 A non-repetitive peak forward current t = 8 ms; square wave − 17.5 A IRSM non-repetitive peak reverse current tp = 100 μs − 0.5 A Tstg storage temperature −65 +150 °C Tj junction temperature − +150 °C VR continuous reverse voltage IF continuous forward current IFSM Tamb ≤ 25 °C; note 1 Note 1. Device mounted on a printed-circuit board, single sided copper, tinplated, mounting pad for cathode 6 cm2. 2003 Jun 27 2 NXP Semiconductors Product data sheet Low VF (MEGA) Schottky barrier diode PMEG6010AED ELECTRICAL CHARACTERISTICS Tamb = 25 °C; unless otherwise specified. SYMBOL VF IR Cd PARAMETER continuous forward voltage continuous reverse current diode capacitance CONDITIONS MAX. UNIT IF = 0.1 A 400 mV IF = 1 A 650 mV VR = 60 V; see Fig.3 350 μA VR = 60 V; Tj = 100 °C; notes 1 and 2 8 mA VR = 4 V; f = 1 MHz; see Fig.4 60 pF Notes 1. Pulse test: tp = 300 μs; δ = 0.02. 2. For Schottky barrier diodes thermal runaway has to be considered, as in some applications, the reverse power losses PR are a significant part of the total power losses. THERMAL CHARACTERISTICS SYMBOL Rth j-a PARAMETER CONDITIONS thermal resistance from junction to ambient VALUE UNIT in free air; note 1 230 K/W in free air; note 2 180 K/W Notes 1. Device mounted on a printed-circuit board, single-sided copper, tinplated, mounting pad for cathode 1 cm2. 2. Device mounted on a printed-circuit board, single-sided copper; tinplated, mounting pad for cathode 6 cm2. 2003 Jun 27 3 NXP Semiconductors Product data sheet Low VF (MEGA) Schottky barrier diode PMEG6010AED GRAPHICAL DATA MHC635 103 handbook, halfpage MHC636 10−2 handbook, halfpage IR (A) IF (mA) (1) 10−3 (2) 102 (3) 10−4 (1) (2) (3) (4) 10 10−5 (4) 1 0 0.2 (1) Tamb = 125 °C. (2) Tamb = 100 °C. Fig.2 0.4 VF (V) 10−6 0.6 (3) Tamb = 75 °C. (4) Tamb = 25 °C. Fig.3 MHC637 handbook, halfpage Cd (pF) 160 120 80 40 0 0 20 40 VR (V) 60 f = 1 MHz; Tamb = 25 °C. Fig.4 Diode capacitance as a function of reverse voltage; typical values. 2003 Jun 27 20 (1) Tamb = 125 °C. (2) Tamb = 100 °C. Forward current as a function of forward voltage; typical values. 200 0 4 40 VR (V) 60 (3) Tamb = 75 °C. (4) Tamb = 25 °C. Reverse current as a function of reverse voltage; typical values. NXP Semiconductors Product data sheet Low VF (MEGA) Schottky barrier diode PMEG6010AED PACKAGE OUTLINE Plastic surface mounted package; 6 leads SOT457 D E B y A HE 6 5 X v M A 4 Q pin 1 index A A1 c 1 2 3 Lp bp e w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION SOT457 2003 Jun 27 REFERENCES IEC JEDEC EIAJ SC-74 5 EUROPEAN PROJECTION ISSUE DATE 97-02-28 01-05-04 NXP Semiconductors Product data sheet Low VF (MEGA) Schottky barrier diode PMEG6010AED DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. DISCLAIMERS General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to 2003 Jun 27 6 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors. No changes were made to the content, except for the legal definitions and disclaimers. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613514/01/pp7 Date of release: 2003 Jun 27 Document order number: 9397 750 11455
PMEG6010AED,115
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种光耦器件,用于隔离输入和输出电路,具有高输入阻抗和低输出阻抗。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚Vcc。
4. 参数特性:工作温度范围为-55℃至125℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于数字通信、工业控制等领域。
7. 封装信息:采用DIP-6封装。
PMEG6010AED,115 价格&库存
很抱歉,暂时无法提供与“PMEG6010AED,115”相匹配的价格&库存,您可以联系我们找货
