SIT8256AI-2F-18E-156.257800Y 数据手册
SiT8256
0.3 ps Jitter Oscillator for Networking
The Smart Timing Choice
Features
Applications
156.250000 MHz, 156.253906 MHz, 156.257800 MHz,
156.257812 MHz, 156.261718 MHz for Ethernet applications
SATA, SAS, Ethernet, 10Gb Ethernet, XAUI
100% pin-to-pin drop-in replacement to quartz-based oscillators
Computing, storage, networking, telecom, industrial control
Ultra low phase jitter: 0.3 ps
Frequency stability as low as ±10 PPM
Industrial or extended commercial temperature range
LVCMOS/LVTTL compatible output
Standby or output enable modes
Standard 4-pin packages: 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm2
Outstanding silicon reliability of 2 FIT or 500 million hour MTBF
Pb-free, RoHS and REACH compliant
Ultra short lead time
Electrical Characteristics
Parameter
Output Frequency Range
Frequency Stability
Operating Temperature Range
Supply Voltage
Current Consumption
OE Disable Current
Standby Current
Duty Cycle
Rise/Fall Time
Symbol
f
F_stab
T_use
Vdd
Idd
I_OD
I_std
DC
Tr, Tf
Min.
Typ.
Max.
156.250000, 156.253906
156.257800, 156.257812
156.261718
Unit
Condition
MHz
-10
+10
PPM
-20
+20
PPM
-25
+25
PPM
-50
+50
PPM
-20
+70
°C
Extended Commercial
-40
+85
°C
Industrial
1.71
1.8
1.89
V
2.25
2.5
2.75
V
Supply voltages between 2.5V and 3.3V can be supported.
Contact SiTime for additional information.
2.52
2.8
3.08
V
2.97
3.3
3.63
V
31
33
mA
No load condition, Vdd = 2.5V, 2.8V or 3.3V
29
31
mA
No load condition, Vdd = 1.8V
31
mA
Vdd = 2.5V, 2.8V or 3.3V, OE = GND, output is Weakly Pulled Down
30
mA
Vdd = 1.8 V. OE = GND, output is Weakly Pulled Down
70
A
Vdd = 2.5V, 2.8V or 3.3V, ST = GND, output is Weakly Pulled Down
10
A
Vdd = 1.8 V. ST = GND, output is Weakly Pulled Down
45
55
Inclusive of Initial tolerance at 25 °C, and variations over
operating temperature, rated power supply voltage and load
1.2
2
ns
15 pF load, 10% - 90% Vdd
2.2
ns
30 pF load, 10% - 90% Vdd
3.4
ns
90%
Vdd
VOL
10%
Vdd
VIH
70%
Vdd
Pin 1, OE or ST
Input Voltage Low
VIL
30%
Vdd
Pin 1, OE or ST
Input Pull-up Impedance
Z_in
100
250
kΩ
Pin 1, OE logic high or logic low, or ST logic high
2
MΩ
Pin 1, ST logic low
Measured from the time Vdd reaches its rated minimum value
Output Voltage High
VOH
Output Voltage Low
Input Voltage High
Startup Time
OE Enable/Disable Time
Resume Time
RMS Period Jitter
RMS Phase Jitter (random)
First year Aging
10-year Aging
T_start
7
10
ms
T_oe
150
ns
T_resume
6
10
ms
T_jitt
45 pF load, 10% - 90% Vdd
IOH = -6 mA, IOL = 6 mA, (Vdd = 3.3V, 2.8V, 2.5V)
IOH = -3 mA, IOL = 3 mA, (Vdd = 1.8V)
In standby mode, measured from the time ST pin crosses
50% threshold. Refer to Figure 5.
1.5
2
ps
2
3
ps
Vdd = 1.8V
T_phj
0.25
0.3
ps
IEEE802.3-2005 10GbE jitter measurement specifications
F_aging
-1.5
+1.5
PPM
25°C
-5
+5
PPM
25°C
Notes:
1. All electrical specifications in the above table are specified with 15 pF output load and for all Vdd(s) unless otherwise stated.
2. Contact SiTime for custom drive strength to drive higher or multiple load, or SoftEdge™ option for EMI reduction.
SiTime Corporation
Rev. 1.11
990 Almanor Avenue
Sunnyvale, CA 94085
(408) 328-4400
www.sitime.com
Revised March 4, 2013
SiT8256
Pin Configuration
Pin
1
Symbol
Functionality
Top View
Output
Enable
H or Open[3]: specified frequency output
L: output is high impedance. Only output driver is disabled.
Standby
L: output is low (weak pull down). Device goes to sleep mode. Supply
current reduces to I_std.
OE/ ST
2
GND
Power
Electrical ground
3
OUT
Output
Oscillator output
4
VDD
Power
Power supply voltage
OE/ST
1
4
VDD
GND
2
3
OUT
Note:
3. A pull-up resistor of
