SD060SA30A.T
SD060SA30A.T
    SMCDIODESOLUTIONS(桑德斯)
    Module
SD060SA30A.T 数据手册
SD060SA30A TECHNICAL DATA DATA SHEET D0085 REV. – SILICON SCHOTTKY RECTIFIER DIE Applications:  Switching Power Supply  Converters  Free-Wheeling Diodes  Polarity Protection Diode Features:         Ultra low Reverse Leakage Current Soft Reverse Recovery at Low and High Temperature Very Low Forward Voltage Drop Low Power Loss, High Efficiency High Surge Capacity Guard Ring for Enhanced Durability and Long Term Reliability Guaranteed Reverse Avalanche Characteristics Electrically / Mechanically Stable during and after Packaging Maximum Ratings: Characteristics Peak Inverse Voltage Average Forward Current Symbol VRWM IF(AV) Peak One Cycle NonRepetitive Surge Current Junction Temperature Storage Temperature IFSM TJ Tstg Condition 50% duty cycle, rectangular wave form 8.3 ms, Sine pulse (1) - Max. 30 3 Units V A 55 A -55 to +150 -55 to +150 C C Max. 0.49 0.39 0.4 Units V V mA 20 mA 220 pF Electrical Characteristics: Characteristics Forward Voltage Drop Reverse Current Symbol VF1 VF2 IR1 IR2 Junction Capacitance CT Condition @ 3A, Pulse, TJ = 25 C @ 3A, Pulse, TJ = 125 C @VR = 30V, Pulse, TJ = 25 C @VR = 30V, Pulse, TJ = 125 C @VR = 5V, TC = 25 C fSIG = 1MHz, VSIG = 50mV (p-p) (1) in SHD package  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SD060SA30A TECHNICAL DATA DATA SHEET D0085 REV. – Mechanical Dimensions: In Inches ( mm ) Bottom side metallization Ag thickness is 5KA minimum Top side metallization Al thickness is 25KA minimum B A Bottom side is cathode, top side is anode Dimension H =0.01050.001(0.270.026) (It can be customized according to customer requirements) H A 0.060  0.003(1.52  0.08) B 0.054  0.003(1.37  0.08)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SD060SA30A TECHNICAL DATA DATA SHEET D0085 REV. – DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SD060SA30A.T
物料型号:SD060SA30A
器件简介:该二极管适用于开关电源、转换器、续流二极管和极性保护二极管。
引脚分配:底部金属化银厚度至少5KA,顶部金属化铝厚度至少25KA,底部为阴极,顶部为阳极。
参数特性: - 极低的反向漏电流 - 低温和高温下的软反向恢复 - 极低的正向电压降 - 低功耗,高效率 - 高浪涌容量 - 增强的耐用性和长期可靠性的保护环 - 保证的反向雪崩特性 - 封装过程中和之后电气/机械稳定
功能详解:文档提供了最大额定值和电气特性的详细表格,包括峰值反向电压、平均正向电流、峰值一周期非重复浪涌电流、结温和存储温度等。
应用信息:适用于需要高可靠性的应用,如核电控制、航空航天、交通设备、医疗设备和安全设备。
封装信息:机械尺寸以英寸(毫米)给出,底部金属化是阴极,顶部金属化是阳极,尺寸H可以根据客户需求定制。
免责声明:文档包含了一些法律声明,包括产品规格和尺寸可能在不通知的情况下更改,以及公司对使用数据手册中信息、产品或电路所导致的任何知识产权主张或其他问题不承担责任。
SD060SA30A.T 价格&库存
很抱歉,暂时无法提供与“SD060SA30A.T”相匹配的价格&库存,您可以联系我们找货
