1C754.T
1C754.T
    SMCDIODESOLUTIONS(桑德斯)
    1C754.T
1C754.T 数据手册
1C754 TECHNICAL DATA DATA SHEET D0124 REV. - SILICON ZENER DIE Features:   Zener Voltage 6.8V Withstand Large Surge Stresses Maximum Ratings: Characteristics Power Dissipation Forward Voltage Max. Junction Temperature Max. Storage Temperature Symbol PD VF TJ Tstg Condition Derate above 25 C @ IF=200mA, Pulse, TJ = 25 C - Max. 500 1.1 -65 to +175 -65 to +175 Units mW V C C Electrical Characteristics @ TJ=25 C: Zener voltage Device 1C754 Zener Impedence Leakage Current Max. IR @ VR Nom. VZ ① @ IZT Max. ZZT @ IZT Volts mA Ω uA Volts 6.8 20 5 2 4 Note: ①Vz Tolerance is ±5%  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1C754 TECHNICAL DATA DATA SHEET D0124 REV. Mechanical Dimensions: In Inches (mm) Bottom side metalization Au-4kÅ minimum Top side metalization Al -25kÅ minimum B A Bottom side is cathode, top side is anode Dimension H =0.010  0.002(0.250.051) (It can be customized according to customer requirements) H A 0.023  0.002(0.58  0.05) B 0.015 0.002(0.38  0.05) DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior not ice to improve product characteristics. Before ordering, purchasers are advised to contact the Sensitron Semiconductor sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall Sensitron Semiconductor be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). Sensitron Semiconductor assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall Sensitron Semiconductor be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or Sensitron Semiconductor. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed writ ten permission of Sensitron Semiconductor. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
1C754.T 价格&库存
很抱歉,暂时无法提供与“1C754.T”相匹配的价格&库存,您可以联系我们找货
