BYV29X-600,127
BYV29X-600,127
    WEEN(瑞能)
    ITO220FP-2
    DIODE GEN PURP 600V 9A TO220F
BYV29X-600,127 数据手册
IMPORTANT NOTICE 10 December 2015 1. Global joint venture starts operations as WeEn Semiconductors Dear customer, As from November 9th, 2015 NXP Semiconductors N.V. and Beijing JianGuang Asset Management Co. Ltd established Bipolar Power joint venture (JV), WeEn Semiconductors, which will be used in future Bipolar Power documents together with new contact details. In this document where the previous NXP references remain, please use the new links as shown below. WWW - For www.nxp.com use www.ween-semi.com Email - For salesaddresses@nxp.com use salesaddresses@ween-semi.com For the copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) “© NXP Semiconductors N.V. {year}. All rights reserved” becomes “© WeEn Semiconductors Co., Ltd. {year}. All rights reserved” If you have any questions related to this document, please contact our nearest sales office via email or phone (details via salesaddresses@ween-semi.com). Thank you for your cooperation and understanding, WeEn Semiconductors BYV29X-600 Rectifier diode ultrafast Rev. 02 — 4 September 2007 Product data sheet 1. Product profile 1.1 General description Ultrafast, epitaxial rectifier diode in a SOD113 (TO-220F) plastic package. 1.2 Features n Fast switching n Soft recovery characteristic n Low forward voltage drop n Low thermal resistance n Isolated package n High thermal cycling performance 1.3 Applications n Output rectifiers in high frequency switched-mode power supplies n Discontinuous Current Mode (DCM) Power Factor Correction (PFC) 1.4 Quick reference data n VRRM ≤ 600 V n VF ≤ 1.11 V n IF(AV) ≤ 9 A n trr ≤ 60 ns 2. Pinning information Table 1. Pinning Pin Description 1 cathode (k) 2 anode (a) mb mounting base; isolated Simplified outline Symbol k mb a 001aaa020 1 2 SOD113 (2-lead TO-220F) BYV29X-600 NXP Semiconductors Rectifier diode ultrafast 3. Ordering information Table 2. Ordering information Type number BYV29X-600 Package Name Description Version TO-220F plastic single-ended package; isolated heatsink mounted; 1 mounting hole; SOD113 2-lead TO-220 ‘full pack’ 4. Limiting values Table 3. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VRRM Conditions Min Max Unit repetitive peak reverse voltage - 600 V VRWM crest working reverse voltage - 600 V VR reverse voltage square waveform; δ = 1.0; Th ≤ 100 °C - 600 V IF(AV) average forward current square waveform; δ = 0.5; Th ≤ 85 °C - 9 A IFRM repetitive peak forward current t = 25 µs; square waveform; δ = 0.5; Th ≤ 85 °C - 18 A IFSM non-repetitive peak forward current t = 10 ms; sinusoidal waveform - 91 A t = 8.3 ms; sinusoidal waveform - 100 A Tstg storage temperature −40 +150 °C Tj junction temperature - 150 °C BYV29X-600_2 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 02 — 4 September 2007 2 of 10 BYV29X-600 NXP Semiconductors Rectifier diode ultrafast 5. Thermal characteristics Table 4. Thermal characteristics Symbol Parameter Rth(j-h) thermal resistance from junction to heatsink with heatsink compound; see Figure 1 Rth(j-a) thermal resistance from junction to ambient in free air Conditions without heatsink compound Min Typ Max Unit - - 5.5 K/W - - 5.9 K/W - 55 - K/W 001aaf257 10 Zth(j-h) (K/W) 1 10−1 δ= P tp T 10−2 t tp 10−3 10−6 T 10−5 10−4 10−3 10−2 10−1 1 10 tp (s) Fig 1. Transient thermal impedance from junction to heatsink as a function of pulse width 6. Isolation characteristics Table 5. Isolation limiting values and characteristics Th = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Visol(RMS) RMS isolation voltage from all terminals to external heatsink; f = 50 Hz to 60 Hz; sinusoidal waveform; relative humidity ≤ 65 %; clean and dust free - - 2500 V Cisol isolation capacitance from cathode to external heatsink; f = 1 MHz - 10 - pF BYV29X-600_2 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 02 — 4 September 2007 3 of 10 BYV29X-600 NXP Semiconductors Rectifier diode ultrafast 7. Characteristics Table 6. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Static characteristics VF IR forward voltage reverse current IF = 8 A; Tj = 150 °C; see Figure 2 - 0.97 1.11 V IF = 8 A; see Figure 2 - 1.12 1.26 V IF = 20 A; see Figure 2 - 1.31 1.45 V VR = 600 V - 2 50 µA VR = 600 V; Tj = 100 °C - 0.1 0.35 mA Dynamic characteristics Qr recovered charge IF = 2 A to VR ≥ 30 V; dIF/dt = 20 A/µs; see Figure 3 - 40 70 nC trr reverse recovery time IF = 1 A to VR ≥ 30 V; dIF/dt = 100 A/µs; see Figure 3 - 50 60 ns IRM peak reverse recovery current IF = 10 A to VR ≥ 30 V; dIF/dt = 50 A/µs; Tj = 100 °C; see Figure 3 - 3 5.5 A VFR forward recovery voltage IF = 10 A; dIF/dt = 10 A/µs; see Figure 4 - 3.2 - V BYV29X-600_2 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 02 — 4 September 2007 4 of 10 BYV29X-600 NXP Semiconductors Rectifier diode ultrafast 003aab482 25 IF (A) 20 15 10 (1) (2) (3) 5 0 0 0.4 0.8 1.2 VF (V) 1.6 (1) Tj = 150 °C; typical values (2) Tj = 150 °C; maximum values (3) Tj = 25 °C; maximum values Fig 2. Forward current as a function of forward voltage IF IF −dl F dt t rr time time VF 10 % Qr VFR 100 % VF IR I RM time 001aab911 001aab912 Fig 3. Reverse recovery definitions Fig 4. Forward recovery definitions BYV29X-600_2 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 02 — 4 September 2007 5 of 10 BYV29X-600 NXP Semiconductors Rectifier diode ultrafast 003aab480 20 Ptot (W) δ=1 003aab481 12 Ptot (W) 10 a = 1.57 1.9 2.2 15 2.8 8 0.5 4.0 10 6 0.2 0.1 4 5 2 0 0 5 10 IF(AV) (A) 15 IF(AV) = IF(RMS) × √δ 0 0 6 IF(AV) (A) 9 a = form factor = IF(RMS) / IF(AV) Fig 5. Forward power dissipation as a function of average forward current; square waveform; maximum values Fig 6. Forward power dissipation as a function of average forward current; sinusoidal waveform; maximum values BYV29X-600_2 Product data sheet 3 © NXP B.V. 2007. All rights reserved. Rev. 02 — 4 September 2007 6 of 10 BYV29X-600 NXP Semiconductors Rectifier diode ultrafast 8. Package outline Plastic single-ended package; isolated heatsink mounted; 1 mounting hole; 2-lead TO-220 'full pack' SOD113 A A1 E z P q m T D HE L2 j L1(1) k Q L 1 b1 2 b w c M e 0 10 z(2) 20 mm scale 0.8 DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1 c D E e HE max j k L L 1(1) L2 max m P Q q T w mm 4.6 4.0 2.9 2.5 0.9 0.7 1.1 0.9 0.7 0.4 15.8 15.2 10.3 9.7 5.08 19.0 2.7 1.7 0.6 0.4 14.4 13.5 3.3 2.8 0.5 6.5 6.3 3.2 3.0 2.6 2.3 2.6 2.55 0.4 Notes 1. Terminals are uncontrolled within zone L1. 2. z is depth of T. OUTLINE VERSION SOD113 REFERENCES IEC JEDEC JEITA 2-lead TO-220F EUROPEAN PROJECTION ISSUE DATE 02-04-09 07-06-18 Fig 7. Package outline SOD113 (2-lead TO-220F) BYV29X-600_2 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 02 — 4 September 2007 7 of 10 BYV29X-600 NXP Semiconductors Rectifier diode ultrafast 9. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BYV29X-600_2 20070904 Product data sheet - BYV29X-600_1 Modifications: BYV29X-600_1 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • • Legal texts have been adapted to the new company name where appropriate. Table 3 “Limiting values” on page 2 updated. Table 4 “Thermal characteristics” on page 3 updated. Table 5 “Isolation limiting values and characteristics” on page 3 updated. Table 6 “Characteristics” on page 4 updated. Figure 1, 2, 3, 4, 5, 6 and 7 updated. 20000201 Product specification BYV29X-600_2 Product data sheet - - © NXP B.V. 2007. All rights reserved. Rev. 02 — 4 September 2007 8 of 10 BYV29X-600 NXP Semiconductors Rectifier diode ultrafast 10. Legal information 10.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 10.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 10.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 10.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 11. Contact information For additional information, please visit: http://www.nxp.com For sales office addresses, send an email to: salesaddresses@nxp.com BYV29X-600_2 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 02 — 4 September 2007 9 of 10 BYV29X-600 NXP Semiconductors Rectifier diode ultrafast 12. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 10.1 10.2 10.3 10.4 11 12 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics. . . . . . . . . . . . . . . . . . . 3 Isolation characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Contact information. . . . . . . . . . . . . . . . . . . . . . 9 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2007. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 4 September 2007 Document identifier: BYV29X-600_2
BYV29X-600,127
物料型号:BYV29X-600
器件简介: - 这是一种超快、外延整流二极管,封装在SOD113(TO-220F)塑料封装中。 - 特点包括快速开关、软恢复特性、低正向电压降、低热阻、隔离封装和高热循环性能。 - 应用领域包括高频开关电源的输出整流器和不连续电流模式(DCM)功率因数校正(PFC)。
引脚分配: - 引脚1:阴极(k) - 引脚2:阳极(a) - 封装类型:SOD113(2引脚TO-220F)
参数特性: - 重复峰值反向电压(VRRM):≤600V - 正向电压(VF):≤1.11V - 平均正向电流(IF(AV)):≤9A - 反向恢复时间(trr):≤60ns
功能详解: - 该二极管具有快速开关和软恢复特性,适用于高频应用。 - 低正向电压降有助于提高电源效率。 - 低热阻和高热循环性能使其适合在高温环境下工作。
应用信息: - 适用于高频开关电源的输出整流。 - 也适用于不连续电流模式的功率因数校正。
封装信息: - 封装类型:SOD113(2引脚TO-220F) - 封装特点:塑料单端封装,隔离散热器安装,1个安装孔。
BYV29X-600,127 价格&库存
很抱歉,暂时无法提供与“BYV29X-600,127”相匹配的价格&库存,您可以联系我们找货
