BYV29-500,127
BYV29-500,127
    WEEN(瑞能)
    TO-220-2
    DIODE UFAST 500V 9A TO220AC
BYV29-500,127 数据手册
IMPORTANT NOTICE 10 December 2015 1. Global joint venture starts operations as WeEn Semiconductors Dear customer, As from November 9th, 2015 NXP Semiconductors N.V. and Beijing JianGuang Asset Management Co. Ltd established Bipolar Power joint venture (JV), WeEn Semiconductors, which will be used in future Bipolar Power documents together with new contact details. In this document where the previous NXP references remain, please use the new links as shown below. WWW - For www.nxp.com use www.ween-semi.com Email - For salesaddresses@nxp.com use salesaddresses@ween-semi.com For the copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) “© NXP Semiconductors N.V. {year}. All rights reserved” becomes “© WeEn Semiconductors Co., Ltd. {year}. All rights reserved” If you have any questions related to this document, please contact our nearest sales office via email or phone (details via salesaddresses@ween-semi.com). Thank you for your cooperation and understanding, WeEn Semiconductors DISCRETE SEMICONDUCTORS DATA SHEET BYV29 series Rectifier diodes ultrafast Product specification September 1998 NXP Semiconductors Product specification Rectifier diodes ultrafast FEATURES BYV29 series SYMBOL QUICK REFERENCE DATA VR = 300 V/ 400 V/ 500 V • Low forward volt drop • Fast switching • Soft recovery characteristic • High thermal cycling performance • Low thermal resistance k 1 VF ≤ 1.03 V a 2 IF(AV) = 9 A trr ≤ 60 ns GENERAL DESCRIPTION Ultra-fast, epitaxial rectifier diodes intended for use as output rectifiers in high frequency switched mode power supplies. The BYV29 series is supplied in the conventional leaded SOD59 (TO220AC) package. PINNING PIN SOD59 (TO220AC) DESCRIPTION 1 cathode 2 anode tab tab cathode 1 2 LIMITING VALUES Limiting values in accordance with the Absolute Maximum System (IEC 134). SYMBOL PARAMETER CONDITIONS MIN. VRRM VRWM VR Peak repetitive reverse voltage Crest working reverse voltage Continuous reverse voltage - IF(AV) Average forward current1 square wave; δ = 0.5; Tmb ≤ 123 ˚C Repetitive peak forward current t = 25 µs; δ = 0.5; Tmb ≤ 123 ˚C Non-repetitive peak forward t = 10 ms current. t = 8.3 ms sinusoidal; with reapplied VRRM(max) Storage temperature Operating junction temperature - 9 A - 18 A - 100 110 A A -40 - 150 150 ˚C ˚C BYV29 IFRM IFSM Tstg Tj MAX. -300 300 300 300 -400 400 400 400 UNIT -500 500 500 500 V V V THERMAL RESISTANCES SYMBOL PARAMETER Rth j-mb Thermal resistance junction to mounting base Thermal resistance junction to ambient Rth j-a CONDITIONS in free air. MIN. TYP. MAX. UNIT - - 2.5 K/W - 60 - K/W 1 Neglecting switching and reverse current losses. September 1998 1 Rev 1.300 NXP Semiconductors Product specification Rectifier diodes ultrafast BYV29 series ELECTRICAL CHARACTERISTICS Tj = 25 ˚C unless otherwise stated SYMBOL PARAMETER CONDITIONS VF Forward voltage IR Reverse current Qs Reverse recovery charge trr Reverse recovery time Irrm Peak reverse recovery current Vfr Forward recovery voltage IF = 8 A; Tj = 150˚C IF = 8 A IF = 20 A VR = VRRM VR = VRRM; Tj = 100 ˚C IF = 2 A to VR ≥ 30 V; dIF/dt = 20 A/µs IF = 1 A to VR ≥ 30 V; dIF/dt = 100 A/µs IF = 10 A to VR ≥ 30 V; dIF/dt = 50 A/µs; Tj = 100˚C IF = 10 A; dIF/dt = 10 A/µs I dI F 15 F TYP. MAX. UNIT - 0.90 1.05 1.20 2.0 0.1 40 1.03 1.25 1.40 50 0.35 60 V V V µA mA nC - 50 60 ns - 4.0 5.5 A - 2.5 - V Tmb(max) / C BYV29 PF / W Vo = 0.8900 V Rs = 0.0190 Ohms dt t MIN. 112.5 D = 1.0 0.5 rr 125 10 0.2 time 0.1 5 Q I I R s 10% D= 0 0 5 137.5 150 15 10 IF(AV) / A tp T t T rrm Fig.1. Definition of trr, Qs and Irrm I tp I 100% Fig.3. Maximum forward dissipation PF = f(IF(AV)); square wave where IF(AV) =IF(RMS) x √D. 12 F BYV29 PF / W Tmb(max) / C 120 a = 1.57 Vo = 0.89V Rs = 0.019 Ohms 10 125 1.9 2.2 8 time VF V fr VF 6 135 4 140 2 145 0 time 0 2 4 IF(AV) / A 6 8 150 10 Fig.4. Maximum forward dissipation PF = f(IF(AV)); sinusoidal current waveform where a = form factor = IF(RMS) / IF(AV). Fig.2. Definition of Vfr September 1998 130 2.8 4 2 Rev 1.300 NXP Semiconductors Product specification Rectifier diodes ultrafast BYV29 series trr / ns 1000 BYW29 IF / A 30 Tj=150 C IF=10 A Tj=25 C 100 20 1A typ 10 max 10 Tj = 25 C Tj = 100C 1 1 0 100 10 dIF/dt (A/us) Fig.5. Maximum trr at Tj = 25˚C and 100˚C 10 0.5 0 1.5 1 VF / V 2 Fig.7. Typical and maximum forward characteristic IF = f(VF); parameter Tj Irrm / A 1000 Qs / nC IF=10A 1 IF = 10 A 100 IF=1A 2A 0.1 10 Tj = 25 C Tj = 100C 0.01 1 10 -dIF/dt (A/us) 1 100 1.0 Fig.6. Maximum Irrm at Tj = 25˚C and 100˚C. 10 -dIF/dt (A/us) 100 Fig.8. Maximum Qs at Tj = 25˚C 10 Transient thermal impedance, Zth j-mb (K/W) 1 0.1 PD 0.01 0.001 1us tp D= T 10us tp T t 100us 1ms 10ms 100ms 1s pulse width, tp (s) BYV29 10s Fig.9. Transient thermal impedance Zth j-mb= f(tp) September 1998 3 Rev 1.300 NXP Semiconductors Product specification Rectifier diodes ultrafast BYV29 series MECHANICAL DATA Dimensions in mm 4,5 max Net Mass: 2 g 10,3 max 1,3 3,7 2,8 5,9 min 15,8 max 3,0 max not tinned 3,0 13,5 min 1,3 max 1 (2x) 2 0,9 max (2x) 5,08 0,6 2,4 Fig.10. SOD59 (TO220AC). pin 1 connected to mounting base. Notes 1. Refer to mounting instructions for TO220 envelopes. 2. Epoxy meets UL94 V0 at 1/8". September 1998 4 Rev 1.300 NXP Semiconductors Legal information DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. DEFINITIONS Product specification ⎯ The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. DISCLAIMERS Limited warranty and liability ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors Legal information NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products ⎯ Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the content, except for the legal definitions and disclaimers. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2011 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands
BYV29-500,127 价格&库存
很抱歉,暂时无法提供与“BYV29-500,127”相匹配的价格&库存,您可以联系我们找货
BYV29-500,127
  • 1+14.077611+1.82132
  • 10+8.8887010+1.14999
  • 100+5.90853100+0.76443
  • 500+4.62894500+0.59888
  • 1000+4.217271000+0.54562
  • 2000+3.870842000+0.50080
  • 5000+3.496045000+0.45231
  • 10000+3.2645110000+0.42236
库存:1766
