SD175SB45B.T
SD175SB45B.T
    SMCDIODESOLUTIONS(桑德斯)
SD175SB45B.T 数据手册
SD175SB45B TECHNICAL DATA DATA SHEET D0119 REV. – SILICON SCHOTTKY RECTIFIER DIE Applications:  Switching Power Supply  Converters  Free-Wheeling Diodes  Polarity Protection Diode Features:         Ultra low Reverse Leakage Current Soft Reverse Recovery at Low and High Temperature Very Low Forward Voltage Drop Low Power Loss, High Efficiency High Surge Capacity Guard Ring for Enhanced Durability and Long Term Reliability Guaranteed Reverse Avalanche Characteristics Electrically / Mechanically Stable during and after Packaging Maximum Ratings: Characteristics Peak Inverse Voltage Average Forward Current Symbol VRWM IF(AV) Peak One Cycle NonRepetitive Surge Current Junction Temperature Storage Temperature IFSM TJ Tstg Condition 50% duty cycle, rectangular wave form 8.3 ms, Sine pulse (1) - Max. 45 30 Units V A 570 A -55 to +175 -55 to +175 C C Max. 0.64 0.57 0.8 Units V V mA 30 mA 1600 pF Electrical Characteristics: Characteristics Forward Voltage Drop Reverse Current Symbol VF1 VF2 IR1 IR2 Junction Capacitance (1) CT Condition @ 30A, Pulse, TJ = 25 C @ 30A, Pulse, TJ = 125 C @VR = 45V, Pulse, TJ = 25 C @VR = 45V, Pulse, TJ = 125 C @VR = 5V, TC = 25 C fSIG = 1MHz, VSIG = 50mV (p-p) in SHD package  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SD175SB45B TECHNICAL DATA DATA SHEET D0119 REV. – Mechanical Dimensions: In Inches (mm) Bottom side metalization Ag-5kA minimum Top side metalization Ag-25kA minimum B A Bottom side is cathode, top side is anode Dimension H =0.01050.001(0.270.026) (It can be customized according to customer requirements) H A 0.175  0.003(4.45  0.008) B 0.163  0.003(4.14  0.08) DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SD175SB45B.T 价格&库存
很抱歉,暂时无法提供与“SD175SB45B.T”相匹配的价格&库存,您可以联系我们找货
